Farmall Tractors Discussion Board
Re: Cub Cooling System
Posted by JW on February 17, 1999 at 17:04:04:
In Reply to: Cub Cooling System posted by Bill Swope on February 17, 1999 at 13:58:44:
The cub is cooled by convection. As water gets hotter, it becomes less dense. Therefore the hotter water rises to the top, and also the cooler (more denser) water sinks to the bottom, therefore creating a circulating pattern within the system.
Post a Followup
: Re: Re: Cub Cooling System
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
