Re: F400 Governor Problem
Posted by Dan on February 22, 2001 at 21:36:24 from (12.18.161.164):
In Reply to: F400 Governor Problem posted by Larry(SD) on February 22, 2001 at 19:02:38:
Larry, you might try lostening the screws on the end of the tube that goes from the governor to the carburetor just move it around a bit and make sure the shaft inside is free. I know if this linkage isn't lined up it can cause a problem. I also understand that the governor spring can get weak over time and needs replacing. I'm going to pull the governor off of my SMTA soon to clean it all up. I don't think it is getting enough oil so need to clean the passage. I had a similar problem with my SMTA and think it was the linkage from governor to carb. Good luck, had the carb off of mine so many times for a while I could have done it blindfolded.
Post A Followup
: Re: Re: F400 Governor Problem
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
