Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: Re: Re: under carriage percentage
Posted by Sean on March 24, 2004 at 08:55:04 from (192.58.199.188):
In Reply to: Re: Re: under carriage percentage posted by MrBill on March 24, 2004 at 07:51:32:
MrBill, No problem, glad to help if I can. I'm trying to learn about all this crawler stuff myself as well. The pins connect the chain links together. They also mesh with the sprocket and transmit the power to the track. The bushings are inside the pins and allow the links to freely pivot so the chain can flex around the sprocket and idlers. Once the pins and bushings are worn to the 25% wear limit (or 75% of their useful wear has been consumed), then they should either be replaced or "turned". The process of turning involves removing the tracks, and then all of the pins in each link on the track are pressed out using a powerful hydraulic ram fixture. Then they are rotated 180 deg and pressed back in. What this does is rotate the less worn side of the pins/bushing to the primary wear side...which will shorten your track and allow you to get more use out of your pins/bushings. From what I've heard though, turning pins and bushings isn't always such a hot idea, especially for small-midsize loaders. Something to the extent that you really don't get much additional wear out of the turned pins bushings. Or in other words the turned pins and bushings don't really buy you another 100% wear cycle. Usually it is advised to simply replace the pins and bushings altogether with new ones while you're paying for the pin press labor. However, on the big dozers, turning pins and bushes is definitely worth it. It can be expensive to have a dealer show up and remove your tracks (or tow away your whole machine), take your tracks to their shop, turn the pins/bushings, and then return and reinstall. It can easily go over $1000 for this procedure (from what I've heard anyway)...but some people remove and install their own tracks and know someone locally that has a pin press who might only charge them ~$500. I've never removed my tracks, but from what I understand it's something a shadetree mechanic can probably do. You need a 15lb sledgehammer, a drift, a VERY trusting friend, an oxy/acetylene torch with a rosebud tip, and a bucket of ice water (for when you reinstall). If you're mechanically inclined and have access to a machine shop, you might actually build your own pin press (like a guy I see on the RedPower forum). But this can be an extremely dangerous process for an amateur, it takes serious force to remove those pins, and if something snapped or went wrong, it WOULD be lethal. Another option is to simply replace your chains altogether. I've heard that a set of new chains for smaller crawlers can be had for ~$2000. This would give you brand new links, pins and bushings. So if your links are down quite a bit in addition to needing a pin/bush turn, this would be a good option. Of course finding a nice used set of tracks with lots of wear left (at a good price) would be even better. Lastly, if you do go with new pins, be aware that if your sprockets are severely worn, this will cause accelerated wear on the pins and sprockets. So, replacing your sprockets is also advisable under these circumstances. (I know...$$$$!!!!) Good luck...
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
