Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: JD 350b, remove 93 series backhoe
Posted by Mark on February 24, 2004 at 15:30:07 from (198.81.26.8):
In Reply to: JD 350b, remove 93 series backhoe posted by MrBill on February 24, 2004 at 11:40:58:
Mr. Bill, A nice level area is ideal. Place the hoe just like you have it in the picture, it does not need to be that far out, but it works, with the teeth in the dirt that keeps the water out. There are 4 pins holding the hoe on. The lower 2 are just used as hooks and you will see that after the hoe is removed. The upper 2 pins should have bolts holding the pins in. Remove the bolts, 9/16" I think, you may need a socket and an open end to do this. Lower the stableizers enough to take the weight off the hoe, tap the upper pins out. Then raise the hoe up evenly on each side using the stableizers and the hoe it self to keep it level, you only need to raise it a few inches to clear the lower hook on the pin. At this point it should be clear of the lower pins, in low gear and while looking over your shoulder, move the tractor forward about 1 foot or so, watching the hyd. lines so that you don't pull them. You just need enough room to fit between the mounting bracket and the stableizer to un do the lines - for you sake, hopefully they are quick-coupler. If not, I think I would make them that way. Shut off the engine, I usually bleed a little of the pressure off, disconnect the hoe, then reconnect the 2 lines to each other on the tractor and on the hoe. It keeps the fittings clean. You should be good to go, it will be a totally different tractor for you. If the hoe sits for a while, it will sink a little in the dirt and also bleed off a little of the pressure and move a little. This is ok, when you want to hook back up just back up in line with the hoe, and just about kissing the tractor with the hoe stop, shut down, bleed the hyd. a little connect your hoses and re-start and now you have power to move the hoe up and down and get it back to level so you can back up under the lower pin, lower the hoe onto the hooks, then use the hoe to tilt the unit so you can get the upper pins in. Good luck
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
