Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: HELP!! JD350b track jumped sprocket!!??!!
Posted by Mark on February 23, 2004 at 14:52:45 from (198.81.26.8):
In Reply to: HELP!! JD350b track jumped sprocket!!??!! posted by MrBill on February 23, 2004 at 06:39:48:
Mr. Bill, The small valve to the right of the main bucket lever is for the rippers in the rear. On my 450C, I turn that and that switches the 4in1 lever to the ripper control. On your track problem; should be simple for you. In order to get the tracks together you need more slack, have someone hold a rag under the area of the bolt on the tension ram. Remove the bolt. There is a little stainless ball in there that will most likely come out, don't loose it. It is only about $1.00 at John Deere, but worth hundreds out in the woods as you tractor is worthless without it. It will be hard to see in all the grease that will come out, if you don't see it come out, thats ok. Use a come-a-long to pull the track together, keep a rag if the ball has not come out, if it's hard to pull, tap on the cyinder housing all around it with a hammer - don't hit the chrome though. Once you get it in place, lined up, and pinned then clean out a little of that grease in the bolt hole with a piece of wire or something, drop the little ball in, replace the bolt hand tight, pump some grease until the track starts to get close to the proper tension. You may see some grease come out under the cyinder from a little hole, but once that little ball finds its seat the grease will stop comming out. My experience has been to keep it a little on the loose side and add 1 pump at a time to get it to proper tension. Keep the bolt adjusted. Run it for a few minutes, check it, add a pump, run it, add a pump, etc... keep the bolt adjusted. Something most likely cause the track to come off - perhaps you could try to avoid what ever happened. I would order one of those little balls and get it in the mail in case you need it. Good luck
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
