Crawlers, Dozers, Loaders & Backhoes Discussion Board |
Re: Re: Re: JD 350b new owner
Posted by jdemaris on December 31, 2003 at 06:08:53 from (209.23.30.122):
In Reply to: Re: Re: JD 350b new owner posted by MrBill on December 30, 2003 at 19:12:28:
John de Marrais here. The 350B doesn't have any converter. A hydraulic reverser (Twin Disk) was optional though, and that's probably what you have. The reverser housing is fastened to the transmission by two studs and nuts on top, and two bolts on the bottom. Besides these four fasteners, there are two dowels that keep the two housings from shucking back and forth keeps them in alignment. These machines did NOT originally have an inherent problem with coming loose. What does happen, is, the first time the machine is pulled apart for a rebuild - usually a blown reverser - the bolts don't get re-installed tight enough. I've had to pull apart new machines, and it's near impossible to get the bolts out without heating them so they'll stretch. I suspect Deere assembled them before having a frame around them. At the dealership, we tried all sorts of tools for removal, but usually wound up using the torches. In reverse, it's difficult to get them in tight enough. Again, we used box wrenchs with chains on them. So, what happens to these machines over time, is the bolts work loose, and the counterbore for the two locating dowels get egg shaped. Once that happens, the transmission does not stay in proper alignment with the reverser, and the splined coupler gets ruined - sometimes also ruining either, or both, of the splined shafts (output from the reverser and input to the transmission). We sold 350 and 450 crawlers for industrial, farm, and forestry. When a logger used a 350 for bunching, they really took a beating. 450s held up much better. Most common failure was the reverser. I suspect if the past owner of your 350B told you it tends to come loose, then it's likely the dowels are hammered out. We had a few occasions where we removed both cases, and sent them to a machine shop to be rebored and oversize dowels installed. It cost a fortune and wasn't worth the bother. We also installed new cases and shafts and a lot of machines. At one point in time, Deere had a "case reclaiming kit" with oversize counterbore tools, dowels, etc., but don't know if such a thing still exists. I have never seen these bolts come loose on a 350 series that had not been already taken apart at least once. Problem is, when the crawler is in assembled form, there isn't room to get an adequate tool on the bolts to tighten them. As far as your backhoe goes, the "barrel" was a weak spot on John Deere hoes. Massey F., Allis, and a few other companys used them. It takes the place of having two separate swing cylinders, but it weak and tends to leak. Deere was selling kits to remove the barrel cylinder and install two conventional and separate swing cylinders. We threw a lot of barrels into the scrap heap after doing conversions. The barrels tend to get scored up and leak a lot. That, and having little swing power, Deere gave them up. I don't know if you can buy major parts for them anymore.
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
