Newholland square baler
Ron
05-19-2003 05:19:50
Any Advice on what to look for in buying a older square hay baler ? New Holland?
SmartAxe
06-07-2003 08:21:48
 Re: Newholland square baler in reply to Ron , 05-19-2003 05:19:50
Not to discourage you from buying a New Holland, because they are good balers. We used to use one for years and it worked great (but liked to eat shear pins). But these days we use a Massey Furgeson 24 and that is ONE HAY BALING MACHINE!!! Just another option to ponder.. NH are good, but I like the MF better (it's quite a few year newer, though). Either way, good luck.
-Mark
Jim in Michigan
06-05-2003 16:41:46
they are all good machines,, old, but good....I have a 68 hayliner I use and a couple 66 balers for backup,,,Jim
johnie
10-19-2003 22:38:04
 Re: Re: Newholland square baler in reply to Jim in Michigan, 06-05-2003 16:41:46
I have a s68 that i just got working seem to bail great but i am new to bailing and would like more info (eg. where to get decals owners manual) also i have found newholland red paint but what is they yellow? cant find new holland yellow any info on these bailers would be a great help
Kelly C
06-03-2003 10:10:56
third party image
I will pass on the advice that was passed to me.
Any New Holland from the model 68 on is good.
JD 14t are ok. JD 24t is fine too.
I got a NH 68 because parts are 1/3rd cheaper if not more from New Holland compared to JD prices.
Example of this. A new Needle for a JD cost about $120 one for a NH is $58
Old JD do make better looking bales. They have a packer fork where the tines need to be adjusted correctly for the NH balers.
I would not be afraid of ether one. as a matter of fact. I now own a NH 268 and am purchasing 3 JD 14t to fix up.
johnie
10-19-2003 22:47:36
 Re: Re: Newholland square baler in reply to Kelly C, 06-03-2003 10:10:56
i have a s68 and hanvent found any difference in the 68 and s68. i just got it running and it seem to bail great but i am new to bailing and dont know a lot about adjusting the bailer. i know how to time it and do have it bailing but need help with the tines my bails are good ont the right but loose on the left.also it seem that the little fingers (look like little c shaped hooks) on the wire tie is draging hard these are new and have no grooves yet are they adjustable? your photo look great i need paint have found newholland red but no newholland yellow what color is it? jd yellow? also need decals and owners manual any help would be a great help.... thanks for your time and your photo it is an inspiation to me
tugboat tim
06-02-2003 11:38:51
if farmin on a tight budget like many of us and not bailin a thousand acres like some. I like the new hollands and not cause I live only 50 miles from where they were made but I bought the oldest newholland that they made a model 66 for ten dollars at a public sale and spent 16 dollars in parts THAT WERE STILL AVAILABLE and have made a thousand bales since and even bought and owners manual for myself as a christmas present. I have been told that the knotters on the old 66 has'nt changed much from the bailers of much later years and yea I'm happy with my old 66 new holland bialer
johnie
10-19-2003 22:54:55
 Re: Re: Newholland square baler in reply to tugboat tim, 06-02-2003 11:38:51
i have an 67 that i bought for part for my s68. although the 67 is string tie and s68 is wire tie i was able to get the parts i needed to get the old s68 rinning. i would like to get an owners manual as well but dont know where to go or how much is acceptable for such a thing. also i have found newholland red paint but know neew holland yellow? is it nh yellow? or just a jd yellow. any info would be a great help as this is my first bailer and i have had to learn as i go. its bailin but i am still learnin HA HA HA
Adam R
05-22-2003 10:04:56
I have a JD 14t baler that was used and abused but after a few cussing sessions it works fairly well.My friend has boath a New Hollend and IH balers and we prefir the Ih better the bales don't have ragged eges and they usually all are the same length, the New Hollend din't ever make two bales the same length last year.
