Using Your Tractor & Crop Talk
Discussion Board - PLASTIC TO COVER ROUND BALES????
JAMIE
12-06-2003 20:11:24
Can the black plastic like you would use under your house be used to cover round bales? I am looking to add to the herd and will need to try and save as much hay as I can so I don't have to rent more hay fields. I am open to any ideas Thanks Jamie
ChrisL
12-09-2003 16:48:39
 Re: PLASTIC TO COVER ROUND BALES???? in reply to JAMIE, 12-06-2003 20:11:24
Well, anything that loses value may be worth protecting if the cost of the protection is not too much, so it depends how long u are going to store the bales, how many bales, how much they cost initally, how much rain/snow u expect, etc
BUT, I wrote for a couple of reasons - I tried putting two rows of bales side by side then with a third row of bales on top in between the two - and covering that with black plastic - was OK until the first 4- mph then it was gone - and I had it tied pretty well -
BUT then I tried a different idea - no extensive results - round bales do store better if you put them on their end, BUT you must protect the top or they will spoil worse than laying them flat. So this is the new idea - I cut a 10'x 10' piece of black plastic - set a round bale on end - put the plastic on like a tablecloth - then run one twine around and tie it on there OPTIONAL: then I would set this bale on top of another bale which was set on end - two bales protected with one piece of plastic. I might try a few more like this nect year
paul
12-10-2003 06:04:57
 Re: Re: PLASTIC TO COVER ROUND BALES???? in reply to ChrisL, 12-09-2003 16:48:39
Around here I see a lot of bales stored like below, & I see why now:
Place a bale on end on the ground, and place one 'normally' on top of it. So the bottom one doesn't spoil from the ground, and the top one sheds off the rain/snow better. Kind of makes a big mushroom.
Nothing beats a good tight bale to start with.
--->Paul
Jim(MO)
12-09-2003 12:00:20
Some farmers around here have put down several inches of gravel under there bale storage areas to help drainage. This is on pretty heavy clay. They claim it reduces spoilage considerably.
Aaron
12-08-2003 13:25:27
If your bales are tight, you will not have hay spoilage. I bale right around 1,000 bales a year, they all sit outside, and have never had trouble with hay being wasted. There is snow on the ground when I move the ring, the cows eat every last bit. I'm also generous on the amount of hay per cow, so I know it's not like I force them to eat it or they get nothing else. I wouldn't go to all the expense of the plastic or the hassel of covering and uncovering the bales.
toolman
12-07-2003 01:14:34
think ya have to be careful with the black plastic as it sweats alot.course it would probably be better than nothing if its gonna get wet where your at.
