Calculating Dry Matter
JoshuaGA
04-17-2008 17:43:49
Didn't want to hijack the tester post, but have a question. I can't find my chart with the formula, so what is the formula for calculating dry matter? TIA
JoshuaGA
JoshuaGA
04-18-2008 17:40:51
 Re: Calculating Dry Matter in reply to JoshuaGA, 04-17-2008 17:43:49
Thanks, I couldn't remember to save my life.
JoshuaGA
ChrisLSD
04-18-2008 12:29:08
you need to know the moisture content of the material...then that percentage is the water...the rest is dry matter..... 2 examples
you harvest corn silage at 65% moisture and are getting a yield in the wagons of 22 tons per acre....
22 tons/acre times 0.65 (65% moisture) = 14.3 tons of water/acre so the rest
22 tons/acre material minus 14.3 ton/acre water equals 7.7 tons dry matter/acre
a 1100 pound square round bale is testing at 15% moisture.....
1100 lb times 0.15 (15%) equals 165 pounds of water in the bale so the rest
1100 - 165 = 935lbs dry matter/bale
