Pulling tractors?
Slo
03-02-2003 17:34:06
How many of you guys pull your tractors?
My first tractor is a MM U, bought to pull with. Pulls 5500 and up. It was followed by a MH 101 that was bought to pull light classes, and sold because it wasn't worth a darn on the front of a sled. It was replaced with a MH 44 that holds it's own in stock class pulling at 4500 - 5500.
77 puller
03-04-2003 11:28:12
 Re: Pulling tractors? in reply to Slo, 03-02-2003 17:34:06
I have a 77 that I pull. I ran my 1850 into about a 5 and a half foot ditch this winter because the snow was drifted and you couldn't see the ditch. We had to go get the log skidder to pull it out. Anyone see that John Deere in the photo gallery that's buried to the top of the rear wheels. It's going to take a heck of a somthing to get him out.
LH
03-02-2003 21:26:25
Im using that MH 101 Super to pull a water cart, plow and disk.
Matt
03-02-2003 19:00:55
I pull my tractors every spring when it gets muddy and i pull them when they don't start.
Stretch
03-02-2003 19:02:53
 Re: Re: Pulling tractors? in reply to Matt, 03-02-2003 19:00:55
Well I was gonna try to be serious on this board, but since you started it...
We know Slo had to buy the second tractor so he could pull-start the first one.
big fred - SERIOUS?
03-02-2003 19:20:51
 Re: Re: Re: Pulling tractors? in reply to Stretch, 03-02-2003 19:02:53
The way I see it, Kim (bless her heart) came a-lookin' for us to start off this board. She oughta know us by now.
Bayou Dave
03-02-2003 18:41:04
I used my 52 Allis WD to pull the neighbor's Ford 3000 out of the mud last week.
Fm...
03-02-2003 17:58:55
I try not to pull mine much--my pop is a bit disagreeable in the process. I don't like it cuz I kin here him cussin even over the dual pipes on the oliver 70 I got.
Mike
Slo
03-02-2003 18:01:28
 Re: Re: Pulling tractors? in reply to Fm..., 03-02-2003 17:58:55
Well, Sliver, maybe if your tractor was actually running, you couldn't hear him cuss... :-)
PeteNY
03-02-2003 17:54:38
Slo, Our 1st choice is our Super C (all of ours are stock, Div. 1) it is real competeive from #3500 up to #5500. The 2N does a pretty good job at #2500 and #3000. The JD 70 pulls well from #7000 on up. We hope to have the Super M on her feet pretty soon, and we'll certainly try hooking the '50 JD B, '49 JD A, and '53 Super H that we didn't have ready last year (we will be pleasantly surprised if either the B or Super H does well, as I have never seen either do REAL well in stock form. Pete
Leroy
03-09-2003 07:52:28
 Re: Re: Pulling tractors? in reply to PeteNY, 03-02-2003 17:54:38
That B and the Super H both should do good, at our local pull we go by plow size class, not weight, the B's usualy are the top pullers, low 1st gear, that 49 A would not do any good, would be pulling against the B & SH, but the A should have the double gear shift and the high speed 1st gear and would be beat out by both the B & SH, limit 1 set of weights or fluid, not both
bob ny
03-02-2003 18:47:53
pete are you any where near walton if you are ,are you going to the cmatmc redneck tractor ride on may 31st
PeteNY
03-03-2003 19:47:47
 Re: Re: Re: Pulling tractors? in reply to bob ny, 03-02-2003 18:47:53
Bob, I am in Binghamton...would love to have more info. could you please email? Tahnks, Pete
tiny
03-02-2003 17:38:44
I was told not to pull (start) my Farmall A it might rip the front end off it.:)
evielboweviel
03-03-2003 15:59:43
 Re: Re: Pulling tractors? in reply to tiny, 03-02-2003 17:38:44
when pulling any tractor should run chain under belly to rear hitch attachment point under rear of tractor.
