Brazing stainless steel
Roger
07-01-2001 19:20:13
Is brazing stainless steel really an inferior method of bonding. i've practiced on a few pieces and it seems to stick quite well and have considerable strength. i'm sure the joint strength is less than tig welding, but i can braze it myself and with less expensive equipment. with some work and metal polish the stainless also polishes up quite nicely too. any feed back appreciated.
RICARDO LOPEZ
07-04-2003 07:44:17
 Re: brazing stainless steel in reply to Roger, 07-01-2001 19:20:13
What is the most adequate filler metal and atmosphere for furnace brazing of 304 stainless steel?
Franz
07-01-2001 20:07:03
OK, it is admittedly weaker, but, do you need the strength in the job you're doing? I have a 50 year old exhaust hood in my house that was soldered. It's still together and looks good.
As to finishing, the SS shops use a straight line sander, like auto body shops use for fibergalss leveling, to restore the brushed finish, and a rotating nylon brush with valve grinding compound for final finishing.
