'37 JD A OIL PRESSURE
Judge
04-10-2001 17:18:48
Had a problem with the original JD guage & had to temporarily replace it with a standard PSI oil pressure guage. I'm getting a reading of 22lbs on the new guage. Is that enough oil pressure? Can't find anything in the manuals about the max & min PSI. Would appreciate any help on this one.Thanks
Ryan
07-26-2001 19:54:45
 Re: '37 JD A OIL PRESSURE in reply to Judge, 04-10-2001 17:18:48
22 psi is sufficent I have a allis model c its only 18 psi at 2100rpm
Brandon
04-11-2001 20:23:59
22 pounds of pressure is enough. My I&T manual says 10-15 psi for the Model A and B.
Our Case VAC only has 12 or so pounds at idle. And the manual says this is OK, plus my grandfather's memory.
Brandon
