Tire sealers
carl
09-24-2000 15:32:37
I just purchased a pair of new 16 inch rims and 6.50x16 firestones from my local TSC. The tires are marked ''tube type" but can I run them tubeless by adding fixaflat? We get a lot of flats and it would sure be easier to plug than repair a tube each time. Opinions and home remedies appreciated.
LURKER
09-25-2000 18:39:41
 Re: tire sealers in reply to carl, 09-24-2000 15:32:37
There is now a new product out. Fix-a-Flat for tubed tires. It is hard to find and costly. I wish I knew what it is called try all the tire shops. Good luck
LURKER
09-25-2000 18:38:24
Frank
09-24-2000 18:00:46
Use the tubes. The liner in a tube type tire is not designed to hold air. Sooner or later the air will seep through the liner and cause a tread separation. This is even more likely if and when you get a puncture. I don't recall seeing any tubeless tires in a 6.50 X 16, but if you can find them you'd be better off.
ANTHONY
09-15-2003 14:39:46
 Re: Re: tire sealers in reply to Frank, 09-24-2000 18:00:46
I PURCHASED ULTRASEAL TIRE SEALANT!! IT ITS SUGGESTED FOR TUBELESS BUT HAD SUCCESS WITH TUBE TYPE. IT NOT 100% BUT IT WORKED FOR ME SO FAR THREE OUT OF FOUR THORN AND BRIARS WERE SEALED.
THEY SAY IT CAN SEAL A 1/4" HOLE. I PURCHASED FROM ULTRASEAL OF NEW JERSEY. 732-736-0046
HOPE THIS MAY HELP YOU!
TAKE CARE
ANTHONY
