Stuck Engine Help
Karl Bader
09-04-2000 08:19:30
I have a John Deere B with a stuck engine. What would be the right thing to do to unstuck it?
Thanks,
Karl
Alex Cameron
12-31-2004 12:21:27
 Re: Stuck Engine Help in reply to Karl Bader, 09-04-2000 08:19:30
Fill crankcase with diesel, let set for a week, remove the head, hold a hardwood stick against each pisto(perferably the size of the cylinder) strike the stick with a hammer to jar it loose
Alex Cameron
12-31-2004 12:19:09
Mark
09-04-2000 09:07:43
First what is stuck pistons, broken internals, how did it get stuck, running and seized, just sitting a long time?
Lets assume (oh no don't make one of those out of me) that the pistons are stuck from just sitting for a long time, fill the cylinders with kerocene
and let it soak for a good long while. Filling the cylinders to the top will not be easy with this engine, try getting it in through the intake or exaust ports after the soak remove the spark plugs, this should cause a lot of kero to spill out if you were succesful at filling then bump the engine back and forth with the flywheel.
