Rumley Oil Pull Tractors
Peter Walton
09-03-2000 20:04:34
I recently saw a rumley at a local steam show. It's fascinating. Can anyone tell a novice like myself why it's called "Oil Pull" I understand this was something to with the cooling system. Did it use oil for cooling??? was the fuel oil also used as the coolant. How did these engines work ? All I could find out from the operator at the show is " It's Really unique" that's about all he would tell me. Sure would appreciate any information at all on these most interesting machine from the past. Also is there a site where i might get technical information on how these things operated. ??? Sure would appreciate any information. Thanks ... Peter ... a new Rumley Nut.
Peter Walton
09-06-2000 04:57:44
 Re: Rumley Oil Pull Tractors in reply to Peter Walton, 09-03-2000 20:04:34
I would like to thank Jon Hagen for the information about the Rumely Tractors. Thanks Jon your information was really helpful, thanks again for taking the time to send me the note. PW
Jon Hagen
09-05-2000 19:47:38
I remembered your post and got a quick look at a Rumely oil pull at the big threshing show at Rollag Minn. Yes they used oil as coolant. From the book"AMERICAN GASOLINE ENGINES" says the oil pull used oil in it's radiator and the higher cylinder temp was part of the reason for their ability to run cheaply on kerosene. They did not use a radiator fan, they have a smokestack like cover on the radiator and have the exhaust blowing out the top of the stack to create a draft to pull cooling air through the radiator.
Take a look at www.rollag.com
Thomas A. Zeller
01-29-2004 13:59:50
 Re: Re: Rumley Oil Pull Tractors in reply to Jon Hagen, 09-05-2000 19:47:38
Does anyone have a picture of a 20-30 -W Series Oil Pull Rumely? Not sure, but think that may be what we have and need to veryify. Thanks. [email protected]
Charles Wessel
03-05-2001 19:53:18
I am interested in information about restoring
a Rumley oil pull.this tractor is available locally. It is a 1911-13 engine#7778. brake hp15
draw bar 30hp. Mfg by Advance Rumley Co.Laporte Ill. also info on value. This unit is parked in a old machinery row on a farm an is mostly complete.
