Displacement/engine speed/HP
John Hallman
08-30-2000 06:56:00
This is more related to newer than older tractors, but there are plenty of experts here.
When evaluating different tractors, I notice that some of the newer tractors have smaller engine displacements but higher rated engine speed, giving the same HP rating as other new tractors and some of the older tractors. What are the implications/advantages of displacement with lower speed vs. small, high speed engines? Is it newer technology that allows the new tractors to run at higher speeds, and is there a wear/durability difference?
Opinions are much appreciated.
Thanks for opening this line of discussion.
09-03-2000 21:13:54
 Re: Displacement/engine speed/HP in reply to John Hallman, 08-30-2000 06:56:00
John & All- Thank you for opening this line of discussion. It involves numerous technical points I've had trouble with for many years.
Torque is brute twisting power applied to a shaft. Horsepower is a meaasure of work and calculations involve time, distance, and mass. They're two different issues.
Long ago, in a tech tng class, I asked a Chrysler tng rep why the short stroke and elevated RPM. Answer came back as "lowered emissions". Bravo sierra!
Do some calculator work on cylinder bore vs crankshaft stroke. It is almost a no-brainer! The long stroke hemi-head engine wins every time. Their smog problems were from the long overlap camshaft grind and the slovenly carburetion needed to make their powerful hemi work.
Look back thru the 70's & early 80's Japanese engine specs and you'll see a bunch of long stroke vs bore hemi head engines in the high MPG and low emissions category.
Very interesting is that the short stroke design has a higher "cold wall quench" ratio and theoretically higher exhaust emissions problem.
What needs to be addressed is that engine power boils down to how much fuel and air can be burned in a unit of time. Run up the RPM and the BTU's used go up accordingly. But, efficiency goes to pot and exhaust emissions go up. A wonderful opportunity to add on lots of "value added" smog equipment...
Modern computer control technology has made it possible to do miracles with the spark ignition IC engine. But, in 1980 I was doing carefully controlled 2 way road test runs with a 1920 Model T Ford and getting 28 - 32 MPG and extremely low exhaust emissions.
Looking forward to more discussion on all this. "Three pedals and a lever", IHank
Ken McWilliams-THINK ABOUT THIS, FELLAS
08-31-2000 18:51:35
John and others think about this.
Most tractors with gasoline engines in the 30 - 50 HP range operate at about 2200 to 2600 rpm and run about 6.5 to 7.5:1 compression.
The flame travel is so fast at these low RPM's that that pre-detonation is not uncommon. One of my several tractors is a John Deere 1020. When I plow or heavily load it, I get the ping from it. When I know I'm going to lug it hard for a long duration I'll use premium gas or throw in a few mothballs (mothballs are made from a close cousin of the benzene and toluene family (unsaturated hexagonal ringed hydrocarbon) which is a component in Turbo Blue Racing Gas) that I keep in the garage to raise the octane.
Automobiles usually are rated at about 4000 - 5000 RPM for the advertised horsepower.
If you would turn up the governors on the tractors to allow the HP to be generated at higher RPM's as was described in the Farmall H story, you could get more power from them. This would be limited somewhat by the intake and exhaust passages and the shape on the camshaft lobes. These will be signifcant restrictions if someone wanted to increase HP more than 50% or so.
The reason that tractor engines endure so well is because the more massive construction of the block, crankshaft and rods. The flip side is that these engines probably wouldn't hold together long at a doubled RPM due to insufficent balancing and low pressure oiling. Due to the high circumferential speed of the bearings at higher RPM's, high pressure oiling is needed to maintain a film of lubricant between the sliding surfaces.
I've seen race engines get trashed in a few seconds after losing oil pressure. Spun bearings is the least, seized engines and thrown rods are the worst.
Chevy small blocks have endured over the years running at high RPM's because they comparitively run smaller rod and main journal diameters which minimizes the circumferential speed between the bearings and the crankshaft journal surfaces.
One of the main ingredients of race engines is a high pressure/high volume oil pump to provide a film of oil to float the bearings on.
Ken McWilliams
Dayton, OH
John H.
09-01-2000 06:16:39
 Re: Re: Displacement/engine speed/HP in reply to Ken McWilliams-THINK ABOUT THIS, FELLAS, 08-31-2000 18:51:35
Ken,
Thanks for the educational comments. It was interesting to hear that you use mothballs in your tank. In addition to being an old tractor buff, I have a Ph.D. in chemistry (unfortunately, playing with old tractors doesn't pay any bills, so I have a real day job), and I know that mothballs are paradichlorobenzene, as you say a relative of benzene and toluene. I would think that you would get deposits or enhanced corrosion of the exhaust system from using the chlorinated compound, over another benzene derivative. When mothballs burn, you generate hydrochloric acid (muriatic acid), which is extremely corrosive.
Just my two cents worth.
Ken McWilliams
09-01-2000 17:29:01
 Re: Re: Re: Displacement/engine speed/HP in reply to John H., 09-01-2000 06:16:39
Dr. John,
I don't use it often.
The HCl will be more corrosive to the aluminum pistons than to the steel and iron.
I reality, a few salts dissolved in water condensate will set up a electolytic cell in a cylinder and form galvanic corrosion to a greater extent. This is what most destroys engines when not put to use.
I tore apart a CASE engine 2 years ago that was seized. It took about 45 - 60 minutes per piston to break the rings out of the piston grooves and clean them. The white powder filled all the gaps.
Ken McWilliams
Dayton, OH
john d
08-30-2000 15:26:42
You bring up some interesting points. While it's not like comparing apples to oranges, comparing these two types of engines is a little like comparing one kind of apple to another - everyone to their own taste!
The old tractor engines, like the ones in my Farmall H, M, and SM have lots of torque, have lasted a long time, and work all day without complaint. Like your 400, they are excellent examples of "high-tech" for their day, considering the basic design was laid down in the 1930's! Look at automotive engines of that day, and you will see some of the same characteristics. The high compression high revving engines didn't start to come along in large numbers until the Olds/Cadillac V8 engines of about 1949 and the Chevy V8 of '55. Sure, there were other engines that had their niche, but these two set some major benchmarks.
It's important to remember that most of the "old" tractors we like so well had only 5 or 6 forward speeds; some had only 4, or even 3! If you don't have lots of gears to choose from, or the ability to shift-on-the-go, you'd BETTER have an engine with lots of torque, and the easy way to get that is LOTS of cubic inches, and preferably with a LONG stroke.
With the benefit of modern lubricants, even with a heavy work schedule, many of these old engines have outlasted their engineer's expectations. No engineer today would be permitted to design an engine (or tractor) with the "extra" strength, material, and longevity that was put into ANY of the major tractor brands of the 40's and 50's. The corporate "bean counters" insist on the most comptetive "bottom line" on the financial report that can be obtained, so engines are lighter, rev higher, and work harder.
It's a testament to the ability of the engineers at Ford, AC, Oliver, MM, IH, Deere, Massey, Case, and others that these tractors are still working the way they are. A tractor produced in the mid-40's followed the advent of really successful tractors by only 20-25 years, and they're still running (and WORKING) 50-55 years later! You won't find that too often in automobiles, trucks, trains, planes, or industrial machinery!
The new ones probably won't last as long, but they weren't really designed with that goal in mind. We live in a pretty much "disposable" society. Empty the can...throw it away.
H MN
08-30-2000 15:45:58
 Re: Re: Displacement/engine speed/HP in reply to john d, 08-30-2000 15:26:42
Hello John d: I posted earlier and it didn't show but your post was real close to what I said. I like your comparing different types of apples. Mother nature has made many things that are somewhat the same ..but each has its slightly different area in which to "do its thing." Same with different designs and what the engineer had to work with ..at that point in time..and what he was allowed to do due to the money aspect. I am finally selling my old Chev with a 2.8L V6 with 154,000 miles. Never touched except for tune up and still runs great and gets 25 MPG. I couldn't have gotten half that with my 1950 Chev straight 6 blue flame engine. Nooo way. Electronic fuel injection computer system in my Olds 3300 V6 would never have been dreamed of 50 years ago. Thats good progress yet I'd rather sit on our old 1941 MD and listen to it handle a steady load. Music to ones ears indeed.. Interesting question 4 sure. Cheers. harvey
john d - with a story of an IH engineer...
08-30-2000 20:08:22
 Re: Re: Re: Displacement/engine speed/HP in reply to H MN, 08-30-2000 15:45:58
Harvey, you make some very good points about the fuel efficiency, ignition, and what the engineers had to work with! By almost all measurable criteria, modern engines are better, but sujectively, nothing beats the sound of one of the old ones (any brand) under load!
My Father has often related to me the story of a conversation he had with another expectant father on the night I was born, in June of 1944. The other man asked what he did for a living, and my Dad told him he was a farmer. When asked if he had a tractor, Dad told him he had a Farmall H, purchased in September of 1943. The man asked if he liked it, and Dad gave him a rave revue!
The man then told Dad that he had been an IH engineer who worked on the development of the H and M models. According to him, field tests of the early H prototype indicated that it could not perform with a 2-plow load at the same level as an M with a 3-plow load. The quick-fix was to turn up the rpms of the H to enable it to perform as planned. He and a couple of other engineers wanted to do a re-design of the H engine and give it more cubic inches, leaving the rpms alone. This plan was turned down in the interest of getting the thing into production, and as a result, the H turns at a faster speed.
Engineers in those days operated with pencil, sliderule, and intuition. Those tractors were built from inspiration, not a computer program.
H MN
08-31-2000 05:15:49
 Re: Re: Re: Re: Displacement/engine speed/HP in reply to john d - with a story of an IH engineer..., 08-30-2000 20:08:22
John d: Thanks for the engineer story. I can relate to that well as I worked in a R&D electronic engineering lab at a large company for 6 years. There are many many factions that go into the developement of some items including many biased human ideas that are not related to the end users needs. For me that was an eye opener. Even so, I still am amazed how well some items are tested during development to protect the user yet keep the price resonable. Quite a process. harvey
B.C.
08-30-2000 13:34:01
Remember that several things improved as time went on. Motor oils are much better than they used to be, engines got fitted with oil filters, and they got better. Fuel injection improved somewhat in Diesel engines. Air and hydraulic filters got better.
It's tempting to say that smaller is less durable, but about the only way you can really do that is to assume that the quality and technology level of what you're comparing is the same.
That said, it's usually seemed to me that the slower running engines lug better than the faster running ones.
Jim WI
08-30-2000 10:38:25
All else being equal, the larger displacement engine will generally develop more horsepower at a given RPM and last longer than a smaller displacement engine.
The rub is in the "all else being equal" part. If one were to design an engine to develop the same horsepower at a given RPM as a 50-year old tractor engine, the new design would likely be quite a bit smaller and last at least as well.
If you're comparing current designs, then the "all else being equal" can be met and the rule will hold up reasonably well.
Another thing to keep in mind is the intended use of the engine. If it's used in a car, it can be designed to have a much higher HP rating than if it's used in a tractor. The reason is that in the car, the engine will rarely be anywhere near it's rated HP while it will normally operate much nearer the rated HP if used in a tractor.
Explain the last paragraph
08-30-2000 12:38:36
 Re: Re: Displacement/engine speed/HP in reply to Jim WI, 08-30-2000 10:38:25
Does the last paragraph say what you really intended to say? If so, then it needs much more explanation to make your point valid.
F14
08-30-2000 13:17:38
 Re: Re: Re: Displacement/engine speed/HP in reply to Explain the last paragraph, 08-30-2000 12:38:36
Makes sense to me. Say your car is rated at 180 HP. This would likely be at somewhere in the neighborhood of 4500-5000 RPM with today's V-6's. How often and how long would you be at that RPM/HP? Maybe for passing, and the odd stoplight-to-stoplight Gran Prix. The rest the time, you're cruising in overdrive, at 1500-2000 RPM, using only a fraction of the rated horsepower of the engine.
A tractor, OTOH, is much more likely to spend hours with the throttle set at PTO-rated RPM, cranking out near-maximum horsepower, while plowing/disking or whatever. Therefore, the engine must be mechanically much more rugged.
Jim WI -- Thanks for the amplification - DNR`
09-01-2000 10:30:38
 Re: Re: Re: Re: Displacement/engine speed/HP in reply to F14, 08-30-2000 13:17:38
AD
08-30-2000 10:32:48
I know this is not in the same class but the same principle. The Diesel engines in railroad locomotives have a top speed of 950 rpm(HP rating from 1500-3000 depending on number of drive motors) and they run for 30 days at a time before being shut down for monthly inspection. They turn a 600 VDC generator and this in turn powers the drive motors. These engines are only shut down once per month for some inspection then started back up. It may be a year before they are shut down for any maintance to be did on them.Out of a 24 hour day the engine will be running at max load for 20 hours on the average. I believe the big and slow beats the fool out of small and fast.Still not convinced that the wear factor don't increase with the increased RPM. Most of the engines in tractors or mowers today need major repair in under 5 years if worked anywhere close to Max load for any extended time.The big and slow was what made the Diesel favored over gas years ago and I still think it applies.
Fred OH
08-30-2000 09:10:53
First of all, John, let me describe myself as not an expert. But I do like the older tractors. I don't have much experience with the newer types. And, like you, I had my curosities about them. I have a neighbor that has a small Ford diesel tractor that he bought down to my place to have me sharpen the blades on the finish mower and mow my place with it as my tractors were out of the county mowing. I thought heres my chance to see some of this newer technology. I wound up hitting a building with it (no damage) and determined it to be the most dangerous piece of equipment that I had ever put myself on. I was glad to take it home. Later, he came down and wanted me to weld the exhaust pipe flange back together which I did. I was uneasy but drove it home ( about 300 yards). When I pulled up to his garage, he had the 16'overhead door off of the garage. Upon questioning him as to what he was doing, he said they had run the tractor through the door. This was why he wanted the exhaust welded. The tractor has a hydrostatic transmission and is real dangerous to me and he is it's experienced operator. Hmmm... If this is the modern technology, I don't think I want any part of it. However, it is great for a tiller in the garden but that's about all the bragging I can do for it. As far as the engine bit of your question, the faster an engine turns, the more fuel it will use and the faster it will wear out. Modern technology! The're getting the horse power from rpm and momentum rather than pure old brute horse power and cubic inch displacement. I'm hoping this will influence you to save one more old tractor. To me, simple, plain, straight forward engineering is the way to go. The newer engineering has limited lifespan designed into it's parts and pitfalls where you have to buy a whole assembly to replace one little part. And the repair parts prices are out of this world, especially from the foreign manufacturers. Although I don't have to farm with them, it's not a smart way for me to buy. I have made my stand. I wonder if theres anyone else who buys my theories? L8R----Fred
John H.
08-30-2000 13:00:20
 Re: Re: Displacement/engine speed/HP in reply to Fred OH, 08-30-2000 09:10:53
Fred, thanks for your comments. I like the older tractors, as I have three Farmalls older than I am! I need a tractor to do some things that my Farmalls can't, so I'm buying a new one. I won't let the old ones go to waste. I'm selling the Farmall 400 and the Cub, but keeping my '46 AV. A better cultivating and row-making tractor I've never seen.
Dean
08-30-2000 08:35:02
John, you bring up an interesting point. Automobile engines have undergone the same transformation in the quest for better gas mileage and lower emissions. I assume the same is true with tractor engines. With modern oils, especially the synthetics, wear does not seem to be a major issue. However, I'm an old-timer and in my opinion, I'll always favor a large displacement engine that is never asked to work hard over a small displacement engine that must be revved high to produce any useable power. The larger engine will never encounter the stress the smaller engine will.
My 32 year old tractor engine still runs like new. I wonder how many of these newer, smaller engines will be running 32 years from now!
Dean
John H.
08-30-2000 08:41:44
 Re: Re: Displacement/engine speed/HP in reply to Dean, 08-30-2000 08:35:02
Dean, thanks for the note. I agree with you, especially on the older tractors. My Farmall 400 runs real slow, but pulls great.
The choice I was considering was between a Long tractor and a Kubota/NH/JD new tractor. The three majors have similar sized engines in the 38-42 HP class, about 134 cubic inches. The Long, in their 45 HP tractor, has a 195 ci engine, quite a difference.
Tom-Pa
08-30-2000 11:18:46
 Re: Re: Re: Displacement/engine speed/HP in reply to John H., 08-30-2000 08:41:44
I have talked to several Long owners lately and they all said it works like the older tractors. I guess it is the larger displacement. One gent also has a 3 yr old JD. and a 5 yr old NH. The Long outworks both of them. I was quite surprised when he told me that.
Good day
Tom
