Does anyone have experience w/ FORD 532 Balers?
MikeM
05-25-2000 20:06:31
Hi Guys,
I have one of these babys w/ a problem with one of the strippers (not) taking the twine off the bill hook. Has anyone ever had to adjust the stripper on one of these things???
-Mike
David
05-26-2000 10:26:05
 Re: Does anyone have experience w/ FORD 532 Balers? in reply to MikeM, 05-25-2000 20:06:31
It has been my experience that this happens as a result of the bill hook being to tight or the clearance between the stripper and hook being to much. I have heard that that stripper can be bent to take up the clearance. I have not tried this since it appears to be a cast part. Instead I replace the bill hook and/or the stripper.
Also a easy fix is to use a thicker twine.
MikeM
05-26-2000 19:35:52
 Re: Re: Does anyone have experience w/ FORD 532 Balers? in reply to David, 05-26-2000 10:26:05
Hi David,
I ended up opting for bending the support arm 10/1000 of an inch or so. I used a pipe wrench!! Would you believe it worked! I used old crappy broken-bale dusty hay from my father-in law's barn to test the baler out. I put a big tarp over his hay-elevator and sent down about 5-7 bales worth.
Overall, do you like the 532??? I've never cut/baled hay in my life and am new to farming. I bought the 532 (w/500 kicker) at an auction and kind of refurbed the thing. I lubed it up real good and went through the bale chamber w/ a grinder outfitted w/ a wire wheel....came out pretty good. I'm not sure if I'm better off w/ a NH or something.
Thanks,
Mike
David
05-30-2000 10:26:03
 Re: Re: Re: Does anyone have experience w/ FORD 532 Balers? in reply to MikeM, 05-26-2000 19:35:52
The one I had was a good bailer, just dont get in a hurry and keep everything adjusted. I traided mine for a 315 NH. The parts on the Ford are getting more and more expensive.
Jason Inman
10-17-2006 17:01:25
 Re: Re: Re: Re: Does anyone have experience w/ FOR in reply to David, 05-30-2000 10:26:03
Dave where have you found part's for your old trade in, FORD 532. I'm looking for a few of the HAYDOG Springs?
