Tractor Talk Discussion Forum
Kuboda Engine help
J Schwiebert
06-04-2007 18:36:42
A good friend of mine is looking for some Kuboda engine help. Right now need to determine the model and how to time the fuel system. Thanks in advanve. J.
Walt Davies
06-04-2007 19:56:34
 Re: Kuboda Engine help in reply to J Schwiebert, 06-04-2007 18:36:42
Why does he need to time the pump it should never need timing if left alone. If it was removed then you better get a manual or someone who knows how to do it. Its not a job for the do it yourself mechanic. The manual on my L285 Kubota says to take it to the dealer to be Worked on. If you install it incorrectly you can ruin the rack adjustment and the engine may run away on you. Personally I wouldn't touch it with a very manual at my side and I have been doing this stuff for 40 years. There are just many different types and setups on these systems.
Walt
Luke S
06-05-2007 06:10:54
 Re: Kuboda Engine help in reply to Walt Davies, 06-04-2007 19:56:34
John is not exactly a do it yourself mechanic. He probably has more experience working on old tractors than anybody on this board.
Wish I could help you John, but I have never had a Kubota give me any trouble as to have to work on it. I got one I have had ten years and have never done more than change the oil and filters.
kopeck
06-04-2007 18:43:24
I think we need a little more info.
There (if it's like my Kubota) should be a model number stamped near the injector pump.
If it's the style pump I have timing is accomplished by shimming the pump, but I don't know if they're all that way though.
K
