John Deere 730 Diesel
Archer
04-27-2000 18:44:16
I have a 1959 730 diesel that runs good, but it has an oil like sludge that leaks from between the muffler and exhaust manifold pipe. Is this a ring problem or something else
steve rasmusson
07-20-2003 08:22:44
 Re: John Deere 730 Diesel in reply to Archer, 04-27-2000 18:44:16
I HAVE A 1959 730 JD DIESEL TRACTOR. IT HAS WIDE FRONT,FACTORY 3PT HITCH, FACTORY FENDERS,993 HOURS,GOOD METAL AND PAINT. IT HAS ALWAYS BEEN SHEDDED. IT ALSO HAS THE GAS PONY MOTOR. DOES ANYBODY KNOW THE REAL VALUE OF THIS TRACTOR?
clooney
04-28-2000 16:49:02
Archer, that black "goo" is normal if you just idle the tractor around or don't run it very hard. The diesel fuel and combustion water vapor mix & create that black "goo" that will seep out where ever it can. If you run the tractor hard under load for a while it will go away, if it doesn't then look for a problem.
PAT
02-01-2002 09:49:37
 Re: Re: John Deere 730 Diesel in reply to clooney, 04-28-2000 16:49:02
ARCHER, I HAVE A720D, 730D, 80D, AND A 820D. ONLY THE 820D STARTED TO MAKE THIS 'GOO'. IT WASN'T LONG AFTER THAT IT STARTED TO GET LOOSE IN THE BOTTOM END(KNOCKING!) I HAVE TO BELIEVE THAT YOUR TRACTOR IS GETTING VERY TIRED, MAYBE NEEDING A MOTOR JOB. THAT'S WHAT CURED OUR 820D. SORRY FOR THE BAD NEWS, BUT WORN RINGS WILL ALLOW OIL TO SEEP BY AND THERE IS YOUR GOO. USALLY FOLLOWED BY A RAIN STORM OF BLACK DROPLITS APON THROTTLING UP THE TRACTOR.
Archer
04-29-2000 07:07:20
Clooney, thanks for the info, the 730 has been idling alot because I've been working on it here and there. I'll give your advice a try.
