Tractor Talk Discussion Forum
Using longer pickup tines on JD535 hay roller
69zfarmer
05-25-2008 07:41:49
I have a early JD 535 hay roller that has been good to me and still is in top shape.It has the yellow pickup so it does not clean the ground as i would like.Can i just buy the longer green pickup tines and install them or they other issues like timing on the reel rotation?
cannonball
05-26-2008 09:06:00
 Re: Using longer pickup tines on JD535 hay roller in reply to 69zfarmer, 05-25-2008 07:41:49
JD parts shows 2 different pickup frames one for short and one for long...
MAY GOD BLESS THE USA
sd pete
05-25-2008 07:47:48
Most of those early rounders had poor pickups. NH would be the exception. Those teeth are supposed to run just above the ground not on it. Do you turn your hay before baling that does help.
