Tractor Talk Discussion Forum
JD A 2spd.trans.
tork rench
05-24-2008 07:08:32
Hello,from Mn.,question-a John Deere A I am looking at has a high -low tranny it does not work in high in reverse he said it was designed that way from the factory,any truth to this?
J. Wondergem
05-24-2008 16:37:01
 Re: JD A 2spd.trans. in reply to tork rench, 05-24-2008 07:08:32
When I was a kid, we had a 37 B, and the lockout was either broken or taken out, before we got it. The only way you could use high reverse was in a big open field.
RobMD
05-24-2008 10:30:16
In addition to the below, a 6 mph reverse is NOT FUN.
old
05-24-2008 09:54:39
Yep the high is set up that way and is just how it is suppose to be. My 1935 JD-B is the same way and has been since it was new. Its even in the owners manual which I also have which is also the one that came with it as in its not a reprint but its also a 1935 manual
DRL
05-24-2008 07:34:33
The reverse is plenty fast (almost too fast) on the low side. Would be quite a ride on the high side.
greenmech
05-24-2008 07:21:57
It has a safety feature built in that shoves it out of high range when shifting into reverse. Sometimes this rod is broken or removed you could have high speed reverse. Ron Mn.
