Tractor Talk Discussion Forum
Hydraulic remote on Super A
Tim Stephenson
05-20-2008 07:38:17
Anyone ever added a remote on a super A. I have a hay rake that required power up and down that I would like to use on my Super A. Thanks,
Tim
Pete7
05-20-2008 16:30:00
 Re: Hydraulic remote on Super A in reply to Tim Stephenson, 05-20-2008 07:38:17
Hi Tim.
I have a Super A with remote's that I added. Use the remotes to angle a snow plow in the winter and for adjusting the depth of a garlic digger in the summer.
NawlensGator mention a machined piece used to tap into the hydraulics. Try this link to a by-pass block that's for sale on Ebay or send me a email for more info about it.
Pete
Fluggie in Ia
05-20-2008 07:55:27
My Farmall A has a live pump added to the front directly off where the hand crank would go. Then various valves for the pieces of equipment I have. I have a IH 1000 one arm loader on it, a belly mower under it and the rear hitch has been converted to a 3 point lift with Cat 1 arms. I want to add a dual hydraulic coupler for a remote cylinder so I can lift my hyd cycle mower or my flare box or a wood splitter. If you'd like to see what it looks like, I can shoot some pictures and e-mail them.
Tim Stephenson
05-20-2008 10:06:41
 Re: Hydraulic remote on Super A in reply to Fluggie in Ia, 05-20-2008 07:55:27
I would love to see the set up. Mine has a full time pump that operates the two enclosed cylinders right under the gas tank. This gives me 3 point and from cultivator control but no remote conections. I was wondering if anyone had ever tee into these existing lines and riged a remote conection. Seems like you would have to have valves to isolate the existing system otherwise it would just bypass through the existing control system. Please send me pictures of your set up. Perhaps I could just have a dual system, one like yours for remotes and leave the existing system alone.
NawlensGator
05-20-2008 10:18:36
 Re: Hydraulic remote on Super A in reply to Tim Stephenson, 05-20-2008 10:06:41
They sell a machined splitter block that fits between the hydraulic lines and the TC unit. It bolts right up. You can buy them new (maybe on this site) for about $75. You then need the remote valves and hoses. I saw a cub with 4 separate hydraulic controls using the cub splitter block.
Tim Stephenson
05-20-2008 12:45:58
 Re: Hydraulic remote on Super A in reply to NawlensGator, 05-20-2008 10:18:36
Thanks for the info, This will be a wonderful addition to my super A.
Tim
