Tractor Talk Discussion Forum
4020 timing
fred siebert
05-18-2008 20:33:40
I just overhauled my 4020, main bearings pistons rods etc. I did not pull the crank or cam. while putting the oil pump back in the rod from the diesel pump fell out so I had to pull the diesel pump. Now I cannot get the tractor timed, according to the way the servce manual says. Has any one else had this problems or any ideas.
Thanks
u can reply here or shoot me an email at [email protected]
Bob
05-18-2008 20:58:59
 Re: 4020 timing in reply to fred siebert, 05-18-2008 20:33:40
Do you have the oil pump installed so the oil pump gear's IP drive slot is as shown in the book?
Also you are aware the IP driveshaft can be installed 2 ways into the IP, with one being 180� "off", right?
fred siebert
05-19-2008 20:02:55
 Re: 4020 timing in reply to Bob, 05-18-2008 20:58:59
can the timing marks get off if the IP rod comes out? I pulled both the the oil pump and the IP and matched them up outside the tractor, there is no way currently that i Can see that if they line up like the book says, that I can mount it on the tractor that way, I am talking about a 4020 John Deere if any one else wants to respond
