Tractor Talk Discussion Forum
power steering pump
farm M
05-15-2008 05:55:26
I have a farmall M. There is a seal thats out on the power steering pump. I am getting oil in my crackcase. I am having a hard time finding parts for this pump. Where can I find parts?
farm M
05-15-2008 17:02:00
 Re: power steering pump in reply to farm M, 05-15-2008 05:55:26
I believe its an Behlen power steering.
RustyFarmall
05-15-2008 08:04:48
If your power steering pump is putting oil into the engine crankcase, then you have either a Behlen power steering unit, an M&W aftermarket live hydraulic pump with power steering added, or you have a live hydraulic pump from a super H, super M, 300, 350, 400, or 450. The part that is causing you trouble is a worn out oil seal, but quite often just replacing that seal won't fix it because of so many other worn parts. The Behlen or M&W may be a bit tough to find parts for. The IH pump a bit easier perhaps.
greygoat
05-15-2008 06:42:57
There"s not enough information here to help you!
Is it a factory pump, or an aftermarket pump?
