Tractor Talk Discussion Forum
Chev trucks 6.0 or 8.1L
jmducks
05-11-2008 06:09:22
I am looking to replace my crewcab 5.7 3/4ton. Which motor do I want for pulling and going to fleet farm and hunting? What is the mpg of 8.1 avg and 6.0? Is there a huge difference in power? Does either motor have certain problems? or transmissions? I want to pull 5000-21000 lbs.
OliverGuy
05-11-2008 17:58:22
 Re: Chev trucks 6.0 or 8.1L in reply to jmducks, 05-11-2008 06:09:22
If you"re doing a lot of pulling, buy the 8.1 if you can find it. Coupled to the Allison transmission, it"s a great combo. I have 3 one ton dumps with the 8.1 and their great. Put it this way, I was mad when they stopped putting them in pickups. I"ve got 6.0L"s also--both engines get 8-9mpg when hauling heavy loads all day and the 8.1 has more than enough power.
Oldmax
05-11-2008 16:11:46
I have a 6 ltr 2004 Silverado K2500 Crew Cab with auto trans & 373 rear . It gets 17 MPG 0n road running 60 MPH . & 13.5 MPG pulling a 6000 LB camper again running 60 MPH . But Chev doesn't reccomend pulling over 9400 with this truck .
2x4
05-11-2008 13:05:06
Knowing the year of your truck will help. GM made changes in 1991 & again in 1996 in their big blocks. If its an older truck the 427 (7.0 L.) will do a better job than 6.0. I have both engines & there is no contest; 427 is much more of a load puller. Early 454's were light truck engines & didn't have the long stoke for power but had more speed.
buickanddeere
05-11-2008 11:43:02
I don't see any advantage to the 8100 and just more weight and fewer aftermarket performance parts.
The highest rated 8100 is 340HP vs. 300HP from the most plain basic 6.0L. Even that plain basic 6.0L will make an easy 325+HP with an AirRaid inlet pipe, factory airfilter/box and a performance tune.
The factory LY6 & L76 well exceed the highest output 8100.
8100
The Vortec 8100 (RPO L18) is a V8 truck engine. It is a redesigned Chevrolet Big-Block engine and was introduced with the 2001 full-size pickup trucks. It retains the same bore centers as the old 7.4 L big-blocks, but stroke was upped by 9.4 mm to reach 8.1 L (496 in�) for a total of 107.95 mm bore and 111 mm stroke. It is an all-iron engine (block and heads) with two valves per cylinder. Power output ranges from 225 hp (168 kW) to 340 hp (168 kW to 254 kW) and torque from 350 ft�lbf (470 N�m) to 455 ft�lb (475 N�m to 617 N�m). Vortec 8100s are built in Tonawanda, New York. The Vortec 8100 is the engine used in the largest Uhaul, their 26-foot (7.9 m) truck. GM stopped installing big block V-8's in the Silverado HD trucks in 2008.
L18 Applications:
* Chevrolet Silverado/GMC Sierra 2500HD & 3500 (option)
* Chevrolet Suburban/GMC Yukon XL (option)
* Chevrolet Express 3/4 or 1 ton
* Chevrolet Avalanche 2500 (option)
6000
HO 6000 engine in a 2003 Cadillac Escalade EXT
The Vortec 6000, or LQ4, is a V8 truck engine. It is a bored version of the Vortec 5300. Displacement is 6.0 L (364 in�) from 101.6 mm bore and 92 mm stroke. It is an iron/aluminum (note that 2000 model year engines had cast iron heads) design and produces 300-325 hp (224-242 kW) and 360-370 ft�lb (488-502 N�m). LQ4s are built in Romulus, Michigan and Silao, Mexico.
LQ4 applications:
* Chevrolet Express/GMC Savana
* Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab
The Vortec HO 6000 or VortecMAX, technically the LQ9, is a special high-output version of the Vortec 6000 V8 truck engine originally designed for Cadillac. This engine was introduced in other truck lines as VortecMAX for 2006. It features high-compression (10:1) flat-top pistons for an extra 10 hp (7.5 kW) and 10 ft�lbf (14 N�m), bringing output to 345 hp (257 kW) and 380 ft�lb (515 N�m). LQ9s are built only in Romulus, Michigan.
LQ9 Applications:
* 2003-2007 Chevrolet Silverado SS
* 2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition * 2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option
Generation IV
The Vortec 6000 LY6 is a Generation IV small block V8 truck engine. It shares the same bore and stroke as its LQ4 predecessor, and also features variable valve timing.
LY6 applications:
* 2007-present Chevrolet Silverado HD
* 2007-present GMC Sierra HD
The Vortec 6000 L76 is a Generation IV small block V8 truck engine and features variable cam phasing, along with Active Fuel Management. It can be considered the replacement for the Generation III LQ9 engine. It produces 367 hp (265 kW) at 5400 rpm and 375 ft�lb (495 N�m) at 4400 rpm. Production started in late 2006.
L76 applications:
6200
The 2007 Cadillac Escalade has a 6.2 L Vortec 6200 (RPO L92) engine. It is an all-aluminum design which, while still a pushrod engine, boasts variable valve timing, a first in a mass-produced non-overhead cam V8 engine. The system adjusts both intake and exhaust timing between two settings. This engine produces 403 hp (301 kW) and 417 ft�lb (565 N�m) in the Cadillac and in the GMC Sierra Denali, and underrated at 380 hp (280 kW) and 415 ft�lbf (563 N�m) in the Hummer and in the GMC Yukon Denali .
Applications:
* 2007+ GMC Sierra Denali * 2009+ Silverado 1500
jose bagge
05-11-2008 08:34:52
For the weight you are pulling, I would go with the duramax/allison combo. I've got 100k on my 2500, averaged 17 mpg the whole time according to the computer, and done zero to the engine/ trans. If you are buying a 4x4 check the front hub bearings- replaced both at 75-90k, about $600 per side. Out here, the 2500/duramax combo is more common than the Vortec.
John M
05-11-2008 07:00:45
My new 2500 with the 6.0 is on the way. Parting ways with my Stroke, just more truck than I need. If youre looking used, I would go with the 8.1. I looked for good used ones around, but nobody has any that they are selling, and again, I think the 8.1 was going to be too much for my uses anyways, and there just werent any good used trucks that were for me.
RustyFarmall
05-11-2008 06:36:45
If everything else is the same, rear end ratio, etc, the 6.0 will not get any better MPG than the 8.1, and the 8.1 will walk all over the 6.0 when pulling a load.
John (C-IL)
05-11-2008 06:26:57
My wife's HD2500 CC 4x4 has the 8.1 with the Allison transmission. 9MPG pulling some serious loads at 65 MPH. 13MPG for everyday driving. There is no comparison for power and the allison makes it all work. It pulls a 30,000# load of corn to town with little effort, and 3 tractors on a 14K trailer is a walk in the park.
