Tractor Talk Discussion Forum
front wheel bearing replacment on Buick
JMP
05-08-2008 18:57:47
can any one tell me how to replace front wheel bearing on a 1993 Buick Park Avenue front wheel drive Thanks John
CWL
05-09-2008 09:11:36
 Re: front wheel bearing replacment on Buick in reply to JMP, 05-08-2008 18:57:47
Just be prepared for some sticker shock when you go to purchase the bearing assembly. Also on the one I did I had to heat the bearing assembley attachment bolts. They had loctite on them. I just got them hot enough to release the loctite. That was on an '01 Buick. Good luck.
Vern-MI
05-09-2008 04:41:49
Looks like some had antilock rotation sensor and some did not. Don't let the assembly hang from the sensor cable if it a part of the bearing assembly. Some of the early ones had a sensor which detected the CV joint hub rotation and it was not part of the wheel bearing assembly.
Goose
05-08-2008 19:26:36
On a '93, there will be an ABS wiring harness plugged into the back side of the hub. Also, sometimes the grease seal pulls out of the old hub and remains in the spindle when you pull the hub off the axle. If that happens, you obviously need to pull the old seal out of the spindle before you can install the new hub.
jay-eye-see
05-08-2008 19:07:27
remove hub cap, remove axle bolt with tire on ground ,then jack up , remove tire/rim, brake caliper, rotor. Use a torx bit to remove three bolts on rear flange of bearing housing and slide assembly off axle(halfshaft)
JMP
05-08-2008 19:11:48
 Re: front wheel bearing replacment on Buick in reply to jay-eye-see, 05-08-2008 19:07:27
Thankyou for help never done this on front wheel drive before Thankyou
