Tractor Talk Discussion Forum
Farmall M engine update: won't start again
1 Dollar
05-08-2008 15:02:40
OK, so I finally got a good starter, and I already had the rest of the engine together. Started the engine the first time no problem (video).
http://www.youtube.com/watch?v=AK1TnwxapDk
Hadn't put water in yet, so shut it off real quick to do that, now it won't fire a lick! Still have blue spark.
What do I start looking for? I'm pretty much stumped, cause I changed NOTHING carb and spark wise.
1 Dollar
05-09-2008 13:18:54
 Re: Farmall M engine update: won't start again in reply to 1 Dollar, 05-08-2008 15:02:40
Tried starting fluid, nothing. Fuel is on and there is some in the tank. I'll drain the water and let it dry out and go from there.
Thnaks
El Toro
05-09-2008 14:18:14
 Re: Farmall M engine update: won't start again in reply to 1 Dollar, 05-09-2008 13:18:54
Pull the sparkplugs and see if any water is present when cranking over the engine. Hal
36 coupe
05-09-2008 05:21:29
Did you open the gas tank valve.Dont laugh, I started the Ford yesterday, didnt get far.
El Toro
05-09-2008 03:16:49
Drain the water from the radiator & engine block
then see if the engine will start. You may have an internal leak of coolant. Hal
soundguy
05-08-2008 20:45:46
IC engine needs fuel, spark, air, compression and timing.
if spark is good, and air is good and you havn't changed timing.. and assuming valves ain't hung and you didn't hole a piston.. that leaves fuel.
try here on startin' fluid.. if she fires off.. you know it's fuel.
soundguy
RAB
05-08-2008 15:11:53
Fuel.
Regards, RAB
