Tractor Talk Discussion Forum
Got the sheet metal off
joeMi
05-08-2008 13:17:03
third party image
Got a good start on my project today. All sheet metal is off. Pretty filthy underneath. Guess I'll start with a putty knife and some brake cleaner to find my way back to the cast. Any suggestions on a simple way to remove some grime?
alabamafrog
05-09-2008 01:19:19
 Re: Got the sheet metal off in reply to joeMi, 05-08-2008 13:17:03
Recently I have had real good luck with the oven cleaner from Dollar General. Its $1 a can and really cuts through the grease (and paint). About 10 cans and about 1-2 hours soak time and pressure wash. Sometimes I then have to go back and scrap some spots and do it again.
37chief
05-08-2008 20:24:32
I use simple green in a squirt bottel, and a stiff brush. Scrub it on the dirty areas, and hose it off with water. Using break cleaner will be quite expensive. Stan
flying belgian
05-08-2008 17:33:57
Trailer it down to the local truck wash.
deadeye012
05-08-2008 13:59:10
Steam Cleaner works good to get the first 6 layers of grease, oil and crude off...JB
TxFarmallFan
05-08-2008 13:22:27
245 Massey?
JoeMi
05-08-2008 13:28:06
 Re: Got the sheet metal off in reply to TxFarmallFan, 05-08-2008 13:22:27
Nope, 265
Michael Soldan
05-08-2008 13:18:55
Easy Off oven cleaner, pressure washer, patience, putty knife
Mike (WA)
05-08-2008 13:56:42
 Re: Got the sheet metal off in reply to Michael Soldan, 05-08-2008 13:18:55
If the grease has hardened due to heat and age, use a needle scaler- its an air tool with little metal pieces that go in and out of the tool. For the hardened grease, its the easiest way to do it, because the stuff won't soften up by "conventional" means.
