Tractor Talk Discussion Forum
farmall m stuck in 2-3 gears
joe klein
05-04-2008 18:52:20
I have a m that is stuck in several gears. I tried the usual fixes(remove shifter, reset forks) but i can not budge the forks. they are rock solid stuck. any ideas?
thanks,
joe
218-255-3770
gene bender
05-05-2008 03:57:11
 Re: farmall m stuck in 2-3 gears in reply to joe klein, 05-04-2008 18:52:20
Tie the clutch pedal down and jack up one wheel you are parked in a bind.
:RIVIR
05-04-2008 19:47:23
try and rock the tractor it has pressure on it is it parked on a slope that that can happen, get a friend to help you rock the tractor and you on the gear shift
GA Dave
05-04-2008 19:43:52
Go to the Farmall/ International Harvester site and ask . Lots of good people there also. David. PS It's a common problem.
trucker40
05-04-2008 19:33:17
Maybe jack up right rear wheel.Maybe that will take some pressure off to where you can get it out of gear,
