Tractor Talk Discussion Forum
jd 830 and a three point hitch
Gettin started
05-03-2008 18:38:51
I was wondering if a three point hitch was offered by jd on the 830? If not can one be added with jd or aftermarket parts?
WeirdDeere
05-03-2008 23:11:33
 Re: jd 830 and a three point hitch in reply to Gettin started, 05-03-2008 18:38:51
No factory 3 point on a two cylinder 830. I've seen it rigged up, but it seems like a bad idea to me.
Pictures here: Link
Brandon
buickanddeere
05-03-2008 21:20:17
I've seen a "farmer fix" rigged up on a two cylinder 830. I won't guarantee the hitch was lined up with the proper distances from the pto shaft. You maybe able to take a Saginaw Hitch and jimmy it on there with lots of welding rod.
James22
05-03-2008 18:58:06
JD offered nothing for the old large standard/wheatland 2 cyl models. Have also never seen anything available aftermarket, but have heard someone constructed a homemade unit and either put it on an 820 or 830. If you are inquiring about the new generation 830, factory 3pts were available and I'm sure aftermarket substitutes are/were offered.
