Tractor Talk Discussion Forum
How to time a 4 cylinder Continental?
Tom 43
05-03-2008 17:01:20
How do I time a Continental 4 cylinder flat head in a Massey Harris 30 tractor? This may not be the original engine.
FixaLinc
05-03-2008 18:35:38
 Re: How to time a 4 cylinder Continental? in reply to Tom 43, 05-03-2008 17:01:20
No. 1 cylinder (the one nearest radiator) up on compression stroke when you feel air pushing out spark plug hole on your thumb. The put the dist rotor on #1 mark on dist cap and mag coupling lugs should be horizontal matching the drive on engine that slots should also be horizontal.
DickL
05-03-2008 18:03:13
 I Found It In A Book in reply to Tom 43, 05-03-2008 17:01:20
It states to time to TDC on the flywheel. the books shows
Firing order 1342
Spark plug gap .025
Breaker gap .020
Impluse Coupling
Lag angle, degrees NONE
Valve Clearance Intake .014 H
Exhaust .014H
On Continenal Engine F-162
Hint
05-03-2008 17:49:24
third party image
Bye ear.
FixaLinc
05-03-2008 18:37:12
 Re: How to time a 4 cylinder Continental? in reply to Hint, 05-03-2008 17:49:24
Hint... Maybe put the spark plug wires off the mag in your ears? Or is that what happened to you when young? :)
DickL
05-03-2008 17:45:13
about any engine will start timed at the compression stroke for number one cylinder on top dead center. The advance is normally built in to the magneto or distributor when at run speed.
