Tractor Talk Discussion Forum
John deere 5010
reid5365
05-02-2008 12:49:39
Can the 1000 pto shaft be switched out for a 540 pto shaft or not?? Is there anyway to do it??? Thanks Guys!
cadet trooper
05-02-2008 15:40:59
 Re: John deere 5010 in reply to reid5365, 05-02-2008 12:49:39
Are you talkin about the 13000# 121pto hp or the little utility tractor 5010?
reid5365
05-02-2008 16:13:51
 Re: John deere 5010 in reply to cadet trooper, 05-02-2008 15:40:59
big one
LeJo
05-02-2008 14:43:03
I take it that you checked to see if you don't have both? My 3020 and my son's 4440 have both.
I may be wrong but check. Do you have a manual?
Lee
reid5365
05-02-2008 14:41:41
Its just a good price on a nice tractor with a cab. Why would you forget that??
thurlow
05-02-2008 13:54:57
So, you're wanting to pull a square 'bailer' (that's for paul) and a haybine with a 5010? Is this the early '60s 5010? Man, I'd forget that!!!!! !!!
cobroller
05-02-2008 13:40:36
no
Sparktrician
05-02-2008 13:26:42
Probobaly not the answer you want, but, you can get a shaft adapter. Problem is, you gota run the engine slower to reduce shaft speed or bye bye gearbox(es). That may be hard to do in some operations, to keep neccesary power.
