Tractor Talk Discussion Forum
front end loader
gjw
05-01-2008 10:02:25
yes i have a ford 4000 3cyl. gas my problem is my 3 point is working fine but my frontend loader has gotten very slow or sometimes will not work at all any suggestions on where to start would be appreciated.
Rusty Wheel
05-01-2008 19:05:48
 Re: front end loader in reply to gjw, 05-01-2008 10:02:25
If the three point works good and the pump isn"t noisy I"d check the lift cylinders on the loader to see if either one of them is blowing by the piston. If one of them leaks, the other one probably won"t work either. Also, check the valve and make sure the oil is getting to the cylinders. rw
gjw
05-02-2008 03:33:54
 Re: front end loader in reply to Rusty Wheel, 05-01-2008 19:05:48
thanks that makes sense i will do that when i get off work today thanks again.
Vito
05-01-2008 14:28:53
Did you check the hydraulic fluid level?
Vito
gjw
05-01-2008 15:20:28
 Re: front end loader in reply to Vito, 05-01-2008 14:28:53
yes and fluid level is fine thanks for reply
