Tractor Talk Discussion Forum
1958 Ford 8N tractor
Doreen
05-01-2008 08:01:54
can anyone help me out, I need to know the HP and rpm's on our recently bought 1958 Ford 8N...
buickanddeere
05-02-2008 05:43:33
 Re: 1958 Ford 8N tractor in reply to Doreen, 05-01-2008 08:01:54
Too bad you didn't post here before the purchase. We could have steered you into something more useful for the same amount of money. Live pto, power steering, high volume/high pressure hydraulics that can support a loader or hydraulic implements, a diesel engine, a real drawbar and less of a tendency to roll ontop of it's driver. The later and better optioned 8N series were much better but they are still throwbacks to the 9N & 2N. While I bleed JD green. For used tractors at the price of a Ford. A Massey 35/135 is tough to beat and handles a front end loader without breaking.
jimNCal
05-01-2008 22:30:43
If it's a 4 speed and those fenders are original, it's a 641. Lower right/center of block should be cast 310605 for the '58 & '59 134cid engine. About 35 hp and the pto speed is 540/universal for most tractors of that era. It should handle a 5 foot mower with little problem and even a 6 footer if running at all well. Save yourself a TON of aggravation and money by investing in the operators manual. AND, a service manual if you're going to wrench on it. Best of success and tractor safe.
Keith-OR
05-01-2008 18:46:53
According to Nebraska test Lab.
Test #642 1958 Ford 641 gas
Belt HP---33 hp
Drawbar HP--29 hp
HTH
Keith & Shawn(Special Olympic Gold)
trucker40
05-01-2008 16:01:53
Fenders dont look right for a 600.That dont mean much.
671DKS
05-01-2008 11:47:22
If it is a 1958 it would be a600 series, looks to have the Workmaster writing on the hood which should make a 1959-1962 model 601 series, depending on transmission could be a 641 thru 671. should be on the tranmission housing behind the starter on the flat, you may need to clean off excess paint or so to see it but should say something like 641
****** (numbers for the serial number), appears to me to be a 601 series from what I can see.
good luck, Kent
Keith-OR
05-01-2008 18:04:51
 Re: 1958 Ford 8N tractor in reply to 671DKS, 05-01-2008 11:47:22
Nope, 801 and 601 series came out in 1957..
1957--1001
1958---1977
1959---58312
1960---105943
1961---131427
1962---155531
Keith & Shawn
Doreen
05-01-2008 12:46:06
it does say 641 workmaster, I believe they told us the wrong year when we bought it... thanks for all your help
Doreen
05-01-2008 17:44:35
 Re: 1958 Ford 8N tractor in reply to Bob, 05-01-2008 13:55:51
the serial number is 21283 and model number 641 workmaster
Bob
05-01-2008 19:45:01
 Re: 1958 Ford 8N tractor in reply to Doreen, 05-01-2008 17:44:35
So it's a 1958 "641", a MUCH better (more modern) tractor than the 8N you THOUGHT you had!
ken in texas
05-01-2008 09:51:51
Can,t tell ,but could be an 800 series,which is higher HP.
Bob
05-01-2008 08:06:17
Try again. 1952 was the end of 8N production.
Take a look at the site below to figure out what you have, or post a photo.
If it IS an 8N, it's about 27 engine HP.
Bob
05-01-2008 08:06:17
Doreen
05-01-2008 08:08:54
 Re: 1958 Ford 8N tractor in reply to Bob, 05-01-2008 08:06:17
I do have a photo, but not sure how to post one, do you have an email I send it to? (thanks!)
Bob
05-01-2008 08:18:59
 Re: 1958 Ford 8N tractor in reply to Doreen, 05-01-2008 08:08:54
Send it to [email protected], and I'll post it for you. (After the next 10 or 15 minutes, I'll be away from the 'puter 'til sometime late afternoon or evening.) (CDT)
Doreen
05-01-2008 08:39:46
 Re: 1958 Ford 8N tractor in reply to Bob, 05-01-2008 08:18:59
Thank you!
Bob
05-01-2008 08:59:51
 Well, it's definitely a LATER model than an 8N... in reply to Doreen, 05-01-2008 08:39:46
Take a look for the model and serial number at the location shown in the last photo, and post back. I'm sure someone more familiar than I am with the post-8N tractors will chime in, as well!
Third Party Image
Third Party Image
Third Party Image
Third Party Image
Third Party Image
Doreen
05-01-2008 09:29:02
 Re: Well, it's definitely a LATER model than an 8N... in reply to Bob, 05-01-2008 08:59:51
I will have to check for that information tonight after work and will get back to you tomorrow, thanks for all your help...
thurlow
05-01-2008 09:08:53
I'm no Ford man, but I can guess with the best of 'em..... ..... 600 series?
Doreen
05-01-2008 09:32:01
 Re: Well, it's definitely a LATER model than an 8N... in reply to thurlow, 05-01-2008 09:08:53
do you have any idea what year it might be? they told us it was a 58 at the auction, we want to get a mower for it but need to know the hp and rpms...
thanks for your help
Gerald J.
05-01-2008 10:24:58
 Re: Well, it's definitely a LATER model than an 8N... in reply to Doreen, 05-01-2008 09:32:01
If the PTO shaft has 6 splines its almost sure to be 540 RPM.
Hp, My guess is 35 to 40.
Gerald J.
