Tractor Talk Discussion Forum
Which would have better overall performance???
Dan Swanson
04-30-2008 08:07:57
This on an IH 856, I have 15.5 bias with no weights or ballast and a set of clamp on 15.5 duals. I also have a set of 2 - 16.9 GoodYear Radials with at least 75% tread left. What would be a better overall combination when used in a field work situation, say pulling a 24" spring tooth in plowed ground. The 15.5s with 75%ballast and just air in the duals or the single 16.9 x 38 GY radials with 75% ballast. I know there is more tire on the ground with the dualled 15.5s but am I right in thinking the radial could actually have more compaction but better grip because of being a radial?
Thanks Dan
Eldon (WA)
04-30-2008 22:11:33
 Re: Which would have better overall performance??? in reply to Dan Swanson, 04-30-2008 08:07:57
According to this link, liquid ballast in a radial stiffens the sideway and just makes it act like a bias ply and is detrimental to performance.
flying belgian
04-30-2008 11:19:02
Go with the duals if for no other reason than the ride.
F-350
04-30-2008 11:16:56
I have never seen an 856 with 15.5x38's.They were all sold new in my area with 18.4x38's and most were dualed.
Dan Swanson
04-30-2008 10:56:15
 HP shouldn't be a problem for 24'... in reply to Dan Swanson, 04-30-2008 08:07:57
First of all I'm located in western Nebraska with fairly light soil. Years ago my grand dad used a JD 4030 (the 856 is very close to the same HP) with 15.5 singles and ballast to pull the same 24' two row Crustbuster I have now in plowed ground. The first time over is the toughest and once that's done then it pulls a lot easier. But with the price of fuel the need for economy starts to play a big part.
That said I'll probable stay with the 15.5s.
Thanks for the great help! I've been around farming all my life, parents and inlaws still farm. Starting at 7 years old I spent many years running a GB MM LPgas 60HP, 5 bottom 14" plows, 21 foot drag spring tooths, life was good. But man have equipment and things changed since.
Thanks, Dan
Glenn F.
04-30-2008 10:00:17
You must be pretty limited with single 15.5's on an 856.
The others have answered your question well.
Glenn
Allan In NE
04-30-2008 08:30:53
You think it will even pull it Dan? Don't think ya have enough horse for a 24' spring tooth in plowed ground, do ya?
Dunno,
Allan
third party image
garytomaszewski
04-30-2008 08:28:58
Dan, I think you have to go with the duals, especially in plowed ground, even if not weighted you have way more float and surface contact than any single radial or not.
