Tractor Talk Discussion Forum
bird nest and fire
marlowe
04-29-2008 19:59:36
birds made a nest under the hood of my pickup truck with in the last week so today i use it and the nest catches on fire most of the wiring under the hood is toast ins. says 6000.00 to fix and it only burnt for just seconds before i had it out even have the eggs left. called ins. at 10 AM and it 130 PM the adjuster was out and had repair check in hand by 230 pm with open end if it goes over the 6000
Larry D.
04-30-2008 18:03:17
 Re: bird nest and fire in reply to marlowe, 04-29-2008 19:59:36
My Daughters Toyota had the Dame Problem with Birds Nests, It got to Running sluggish... Got to Checking and the AIR FILTER was "Completely" Covered in a Bird Nest.. I can't believe it got any Air at all..It had been sitting, not driven for about a Week!<> have a GooD un" Larry KF4LKUS
Roy in georgia
04-30-2008 16:31:57
must have built nest at the turbo you should be able to get the wires from the dealer and they just plug up easy $6000 to me wiring harness will prob. hit you in the $100s not $1000s so all that tractor $$ will be handy. It don't matter how much you spend of the $6000 as long as it gets fixed. your finance company wants to see it fixed. you could also check with a local mechanic couple thousand and let him pull the wires still $ in the pocket
marlowe
04-30-2008 16:54:07
 Re: bird nest and fire in reply to Roy in georgia, 04-30-2008 16:31:57
wireing harness is 2200.00
Spook
04-30-2008 14:06:53
I had a mouse nest do the same thing. I put some new plug wires on, that's it.
ScottyHOMEy
04-30-2008 06:48:10
Wow, I'm surprised at that number. Most of your heat is on the exhaust side and most of the wirin', the expensive part anyways, is over on the intake side, where there aren't many things hot enough to light off a birds nest.
36 coupe
04-30-2008 04:53:49
I would work on repairing the truck for a long time for 6 grand.
Dachshund
04-30-2008 04:53:00
Yup. Them Dodges are for the birds....
Glad you got it covered. Who do you have Insurance with?
marlowe
04-30-2008 16:52:39
 Re: bird nest and fire in reply to Dachshund, 04-30-2008 04:53:00
progressive
jose bagge
04-30-2008 04:36:53
they must be thinking computer melt down, huh?
bill mart
04-30-2008 01:28:33
what year is the pickup? bill m.
marlowe
04-30-2008 03:52:08
 Re: bird nest and fire in reply to bill mart, 04-30-2008 01:28:33
2005 dodge diesel
