Tractor Talk Discussion Forum
corn planting/Thanks
Missouri Man
04-29-2008 09:28:27
guys I got my mahindra running and the mower had to much oil in it so I drained some out and now it is all good
thanks
I have about a 3or4 acre field near large creek I was wondering if it was to late to plant field corn and if I would have enough to corn to sell to local farmers? and mabey what corn is worth
Gerald J.
04-29-2008 11:16:42
 Re: corn planting/Thanks in reply to Missouri Man, 04-29-2008 09:28:27
If anything its still early for planting corn. Corn seed likes 56 degrees for good germination. Your ground is probably colder than that and way too wet. In central Iowa yesterday I found the soil temperature was 47, but then it got down to 28 overnight and there was frost on the ground. It will be weeks before corn and beans are planted.
Corn is down today at CBOT, but probably about $5.50 a bushel at your local elevator. If you've never planted corn you might make 80 or 100 bushels per acre. With everything right, the land might make 180 or 200 but you will miss too many details. Been there, done that.
Seed on the other hand runs $150 to $250 per sack and a sack does about 3 acres. Nitrogen fertilizer is necessary and runs $750 a ton and up. Needs maybe 150 pounds of N per acre to produce decent corn. Might need P and K too, only a soil test will tell on the P and K.
You might make more money renting the land to a nearby farmer for cash and let him raise whatever crop his experience says will work.
Gerald J.
Wesley Stephens
04-29-2008 10:52:17
It's not too late to plant corn, but you might want to look at seed and fertilizer costs first. I planted some for silage, and the fertilizer is outrageous.
fixerupper
04-29-2008 10:25:04
Maybe you could seed it to hay. Do you have a neighbor with cattle or horses who will cut, bale and buy it? You wouldn't have to do any work except for seeding it and maybe he would do that too. Jim
