Tractor Talk Discussion Forum
Shibaura SD1840 PTO shaft for tiller
Don Nelson
04-29-2008 08:09:19
I need to find a pto driveshaft for a tiller on a Shibaura SD1840. Tractor has 6 spline 1.37 in/34.85 mm and tiller has 13 spline .98 in/24.9mm
thanks,
Don
geok
04-29-2008 18:43:55
 Re: Shibaura SD1840 PTO shaft for tiller in reply to Don Nelson, 04-29-2008 08:09:19
Most implements that have 13 spline shaft usually runs backwards and faster than a 6 spline.
ScottyHOMEy
04-29-2008 08:37:16
The spline on your tractor is the standard for a 540 rpm pto. If your tiller is esigned to run on 540, any goos tractor/implement dealer will have the yoke for your u-joint at the front of the tiller shaft. You'll just need to have somebody to weld it on.
What I don't know is the size and spline count on ptos of other speeds like 1000 rpm. I know it's a different size so you can't hook up to the wrong one. What it likely boils down to is the input speed required for your tiller. If the tiller is geared for a higher input rpm, it may not be compatible with your tractor. If that's the case, I think I'd look for a diffrent tiller before I'd change out the yoke.
