Tractor Talk Discussion Forum
Model A J.D. tractor how do you get at the fan?
BlaineF
04-28-2008 15:27:17
Well I got the A started after cleaning out the carb and pushing it around the yard with another tractor.Had to also change the spark plugs wires around my bad.Anyways got it fired up started to adjust the carb and all h--- broke out.It looks like some packing on the fan shaft came out from under the fan.The fan hit the shroud. Started to pull the tin off and radiator took the big bolts out on the bottom by front tire .I can't get the radiator to move does it have mounts on top.How does the steering rod come off?What do I need to do to fix the fan.Any help would be great.The help with my stuck carb parts worked out great thanks.
RobMD
04-28-2008 15:31:31
 Re: Model A J.D. tractor how do you get at the fan? in reply to BlaineF, 04-28-2008 15:27:17
You'll have to take the grilles, hood, and steering shaft off.
First, GET A MANUAL AND READ IT.
Second, take the grilles off and remove the two cap screws holding the steering shaft worm in the gearbox. screw steering shaft out. Remove complete hood from the tractor. Rock radiator forward and then remove fan unit.
The next stuff is going to require a manual.
