Tractor Talk Discussion Forum
speaking of tires
glennster
04-28-2008 14:54:11
had a low rear tire on one of my m's, over at the other place. sooo, i loaded up some tools, bottle jack , cribbing, liquid pump, 100 gallon poly tank, fluid adapter. drove over, got the wheel bolts loose, jacked er up, set up the pump, ran all the hoses, went to attach the fill adapter, had the wrong fitting. dang. unhooked the trailer, figgured the john deere dealer would have one, drove about 10 miles to the dealer, nope no gots. drove in to town, stopped at car quest, nope no gots, drove to the napa, nope no gots, ah heck, i'll try and rig something. got back, found some rubber fuel line and duct tape, rigged up a fancy adapter, good to go, hooked er all up, rotated the valve to the bottom and turned the pump on..... nothing came out. primed the pump....nothing. huh, valve must be plugged. poked a stick into the valve....then i realized.....i never got around to loading that tractor with chloride.
iowa_tire_guy
04-28-2008 20:15:57
 Re: speaking of tires in reply to glennster, 04-28-2008 14:54:11
Better to think it is full and be empty than the other way around. I really don't want to talk about it.
RobMD
04-28-2008 15:16:44
It's getting too expensive to drive around for me anymore to fix junk. I know where you're coming from, though. Have to drive all over creation to get things fixed anymore.
