Tractor Talk Discussion Forum
OT How do I get rid of woodbees?
UncleBubbIH
04-25-2008 17:35:09
How do I get rid of woodbees? Please, our farm is about to fly away. And I kind of like Ohio.
Alex.C
04-26-2008 10:37:34
 Re: OT How do I get rid of woodbees? in reply to UncleBubbIH, 04-25-2008 17:35:09
Find each bees hole in the wood and stuff it with freshly chewed gum. trust me it works. they ether leave or die if you plug the hole with them in it.
tn terry t
04-26-2008 05:31:48
 Re: OT How do I get rid of woodbees? in reply to sbin, 04-25-2008 17:35:09
UncleBubbIH said: (quoted from post at 20:35:09 04/25/08) How do I get rid of woodbees? Please, our farm is about to fly away. And I kind of like Ohio.
boy i tell you what ive got so many holes bored in my front porch its pitifull 4 yrs. ago i found some stuff called terminate by spectracide{sp}? anyway its has termite and carpenter ant in big letters on the front but if you read the lable its for over 40 insects it comes with a battery powered sprayer i soak the wood down and NO MORE BEES it kills them if it gets on them or they fly around for a day or so looking for untreated wood and leave its the very best thing ive found it really works as a matter of fact im spraying today
DiyDave
04-26-2008 03:42:22
That shopvac ideer works, I used one to get rid of a nest of yellowjackets once. But that's another subject, I think the op was talking about the solitary big black and yellow carpenter bees that drill holes in, and nest in wood. The hole is drilled up, from underneath, most of the time, then makes a right angle turn and heads toward the nest area, only one bee to each nest. Put a mothball (P-dichlorobenzine) into each hole, and there'll bee no trouble!
rodgernbama
04-25-2008 21:01:44
Try drione powder. You blast it the hle ane they get it on them and die.
james rumph
04-25-2008 18:42:47
We had them behind our sideing as well, i got a can of spay insulation [foam] and filled in the entrance one night and they all died in there. All gone !!!!!
Jiles
04-25-2008 18:09:48
Fill the holes with "Bondo" works good for me.
dittmerku
04-25-2008 18:08:43
This is kind of strange, but it works. We had bees in our house all the time and I finally found out where they were getting in and out from. They had a hive inside our siding. So I took a shop vacuum early one morning and duct taped the hose right where they went in and out. I turned the vacuum on and went to work. As the bees flew in or out they got sucked right up. Came home at the end of the day and sprayed some bee killer into the vacuum, waited and sprayed it again, then dumped it out. There was a pile of bees about 2 feet high! So, I did it the next day and got about half as many. After the third day, the problem was solved, no more bees. Never came back. Years later, when remodeling our kitchen, I took off the drywall and discovered the hive went all the way from floor to the ceiling! Had i taken that drywall off before I discovered the hive, it would have been nasty. Good luck. Kurt
dr sportster
04-26-2008 13:34:09
 Re: OT How do I get rid of woodbees? in reply to dittmerku, 04-25-2008 18:08:43
Good thinking!
rexhellwig
04-26-2008 05:12:33
I guess I won't be heading over to your place to borrow your shop vac. You never know what might be in there...
