Front tractor tires
dave2
04-25-2008 01:25:59
Another tire question folks. The tires on the front of my tractor are 5x16 4 ply. They are fine under normal inflation until I hang the frontloader on, then they kinda squash down a little and get worse when I pick anything up.. Just saw some 8 ply advertised w/ the 3 rib design and some with an actual tread pattern. Would 8 ply handle more load? Or, am I looking at it wrong? Also, the worn out tires that I have now have (had) a tread pattern. When I get new ones, is there a benefit/drawback of one design over the other (tread vs rib)?
Thanks, Dave
dave2
04-25-2008 06:41:21
 Re: Front tractor tires in reply to dave2, 04-25-2008 01:25:59
Here in Germany, tractors go through inspection and get a license plate just like a car. Mine can only have 5x16 or 5.50 x 16 without costing about 200 bucks to go through inspection again and get the paperwork changed.
I just found some 3 rib 8 ply that I'll order.
Thanks, Dave
bellyacre
04-25-2008 06:09:48
If you use your loader a lot,might want to look at taller tires (6.50-
7.50). May not pass the correct police, but i,ve found they roll a lot easier under load.
dave2
04-25-2008 03:47:38
Thanks! 3 rib or tread, or is it a personal preference?
Dave
Fordfarmer
04-25-2008 06:08:02
 Re: Front tractor tires in reply to dave2, 04-25-2008 03:47:38
Fewer ribs tend to bite more when turning - good - if you need to turn sharp, bad - if you're on a lawn. I have 2 85 h.p. tractors - one with 3-rib, one with 4. 3-ribs turn better when it's muddy or snowy. My other tractors all have 3-rib, except the big one, which is front wheel assist.
flying belgian
04-25-2008 05:07:40
Yes it is personnel preferance. We have discussed this before and never really came to conclussion that one is better than the other. I prefer the 4-rib just because I think they look better on the tractor.
IaGary
04-25-2008 02:17:27
Yes 8 ply tires will handle more load than 4 plys.
8ply tires will handle more weight because they will take more air pressure than a 4 ply.
4 plys are barly heavy enough with no loader. Switch to 8s and pump them up.
Gary
