Tractor Talk Discussion Forum
protective coating for tractor gas tank
Pat H.
04-23-2008 07:09:21
I know this subject has been on here before, but I would like information about coating the interior of gas tanks to inhibit rust. How is this done and who does this type of work? Has anyone out there attempted to do this themselves and what were the results? Thanks.
Pat H.
Pat H.
04-23-2008 21:31:43
 Re: protective coating for tractor gas tank in reply to Pat H., 04-23-2008 07:09:21
Thanks to everyone who responded to my questions. I'm in the process right now of getting the problem taken care of. All the comments made a lot of sense.
Pat
dave guest
04-23-2008 20:59:52
Kreem is good. Also Kanter products has kits. Think is was 3 steps. Takes a little time. Kanter was about $40when I did it(truck).
Walt davies
04-23-2008 08:37:49
I spent a lot of time cleaning out tanks that had that red stuff in them. Sooner or later averything will come loose. I found that if you keep gas in them the fumes from the gas will keep them from rusting.
Walt
Bryan In Iowa
04-23-2008 08:09:37
RED Coat ,,avail most part stores , works great .
Bob
04-23-2008 07:19:37
I've had a few done at a favorite radiator shop with GOOD resuls, so far. I don't know what brand of material they use. I think getting the tank CLEAN before coating can prevent diaster from the coating (and chunks of rust) peeling off later.
They are set up to get then tank CLEAN, and are somewhat reaonable, so I haven't attempted to coat a tank myself.
I've seen quite a few writeups on products from The Eastwood Company, and Kreme. They sure make it soung easy to do it yourself.
There's even a Kreme writeup on this site:
dieseldave56
04-23-2008 08:02:56
 Re: protective coating for tractor gas tank in reply to Bob, 04-23-2008 07:19:37
I've restored many vehicles over the years and when an owner wants to keep an OEM fuel tank that has internal rust scale I'd use a sealer. check out this sealer Link
Bendee
04-23-2008 08:12:03
 Re: protective coating for tractor gas tank in reply to dieseldave56, 04-23-2008 08:02:56
Story is you put a dash of metholated spirits {ethanol} in the tank to disperse the water.
