Tractor Talk Discussion Forum
Ford 4000 pto slipping
Larry Cobb
04-21-2008 12:35:58
I recently purchased a 1964 Ford 4000 tractor with a Slecto-O-Speed transmission
The pto tends to slip under heavy load such as my roto tiller Is there any adjustment to the pto Any input whould be appreciated
THEkyroastnear
04-22-2008 19:24:18
 Re: Ford 4000 pto slipping in reply to Larry Cobb, 04-21-2008 12:35:58
nothing to do with your question but where are you located? that happens to be my family name
buickanddeere
04-21-2008 18:56:53
Wrong oil in transmission will also make the clutch packs slip.
DaveH IA
04-21-2008 15:34:16
I would check the adjustment on the cable first--
fordfarmer did you buy the 5000??
Fordfarmer
04-21-2008 12:59:38
Select-o-speeds use a hydraulic clutch for the pto. If your pto slows or stops under heavy load, the cluch is probably worn.
RickB
04-21-2008 15:35:49
 Re: Ford 4000 pto slipping in reply to Fordfarmer, 04-21-2008 12:59:38
Cable adjustment could cause this symptom. It makes more sense to check that first than not.
