Tractor Talk Discussion Forum
MF1155
surveyor120
04-20-2008 14:08:33
recently purchased MF1155 with dealer added turbo but can"t find any info.
JoshuaGA
04-20-2008 17:29:36
 Re: MF1155 in reply to surveyor120, 04-20-2008 14:08:33
Don't think it was standard until the 2000 series. Never have seen the need in diff lock but then again, none of our fields are a straight line. Wouldn't worry. That is a good tractor for the money.
JoshuaGA
JoshuaGA
04-20-2008 16:39:05
I doubt it, not knowing the soil and conditions. My personal preference has always been to pull small equipment faster, not bigger equipment slower. If you feel comfortable with the load your pulling, keep doing it. Those drivetrains can stand plenty of stress, that motor can just add more. Biggest trick is not to overweight it. Should you have some especially tough conditions, that slipping will save you from breaking something. Too much traction will destroy a drivetrain in short order.
JoshuaGA
surveyor120
04-20-2008 16:54:14
 Re: MF1155 in reply to JoshuaGA, 04-20-2008 16:39:05
thanks for the advice.forgot to ask,tractor does not have diff.lock seems unusual for machine this size but I did read in manual this was an option.
JoshuaGA
04-20-2008 16:09:52
Well, I can't help you with the brand, but here's what I can tell you. I would expect to see anywhere from 20 to 40 horse extra out of that motor all stock except for the turbo. Dealer mods are not uncommon, but are ill suted for that tractor. Neighbors had a well motor that came out of a stock 1155. Reason being, that motor destroyed the tractor, too much power for not enough tractor. They were meant to do the same work as an 1135 a gear faster, not to do more work. Shined on the PTO. Concept was shove a bigger motor in a current frame. 2000 series were an improvement when it comes to tillage. DO NOT ask too much of this tractor, it can be overworked. Motor, turboed or unturboed are great. Our Perkins V8 was put on the well in 1980, origional motor, never rebuilt, only internal work was when it dropped a valve. Probally has 20,000 easily, still strong but it isn't pushed. As long as you use it as if it were stock, it will be a great tractor.
JoshuaGA
surveyor120
04-20-2008 16:23:07
 Re: MF1155 in reply to JoshuaGA, 04-20-2008 16:09:52
great info,hard to find many people(dealers)who know anything about them.I've been pleased with tractor so far.I'm pulling a 21'krause disc harrow now... to much?
JoshuaGA
04-20-2008 15:49:42
So what do you need to know?
JoshuaGA
surveyor120
04-20-2008 15:57:48
 Re: MF1155 in reply to JoshuaGA, 04-20-2008 15:49:42
what is the HP boost,was it standard practice for dealers/manufacturers to install these,are there any web links that you know of on this turbo? thanks
