Tractor Talk Discussion Forum
m,f, 4840 rear axle temp reading hot
4840 rookie
04-20-2008 13:55:41
what oil is used in a4840 rear axle and is that also the hyd system oil we are having trouble with that axle oil overheating
04-20-2008 14:50:20
 Re: m,f, 4840 rear axle temp reading hot in reply to 4840 rookie, 04-20-2008 13:55:41
If it is a mf I think they had 80-90 I would have to check at the book. they did have some axle troubles. Neil
mul-skiner
04-20-2008 14:16:57
Yes it is all hyd. oil but I guess the best bet is to pull out the manual and if unsure run down to your Deere dealer and have him run off a copy of the rear axle assembly change the trans.filters ,make sure the oil cooler is clean up by the radiator are you using John deere oil ? I would go with factory suggested oil.Do you have a heat gun to give you the actual trans, temp on the axles. Good luck the 4840 is my alltime favorite tractor
Bob
04-20-2008 14:26:29
 Re: m,f, 4840 rear axle temp reading hot in reply to mul-skiner, 04-20-2008 14:16:57
From the "m,f," in his subject line, I THINK he has one of THESE:
Third Party Image
thurlow
04-20-2008 15:05:39
 Re: m,f, 4840 rear axle temp reading hot in reply to Bob, 04-20-2008 14:26:29
Bob, your picture didn't show..... ...on my computer
third party image
