Tractor Talk Discussion Forum
Idle adjustment screw on Allis G Tractor.
AWB
04-19-2008 11:57:18
Do I turn the idle adjustment screw clockwise or counterclockwise ro lean out the fuel/air mixture? Thanks.
Bob
04-19-2008 12:36:00
 Re: Idle adjustment screw on Allis G Tractor. in reply to AWB, 04-19-2008 11:57:18
My Uncle used to have a "G", but it's been quite a while!
I would suspect it has a little Marvel Schebler carburetor, and if so, likely the mixure is RICHENED as you turn the needle "IN" (CW).
AWB
04-20-2008 05:24:34
 Re: Idle adjustment screw on Allis G Tractor. in reply to Bob, 04-19-2008 12:36:00
Bob: Thank you for the idle adjustment information.
Michael Soldan
04-19-2008 12:33:15
..Uhh the idle adjustment will do just that..adjust the idle, it will not change air/fuel mix..go to the other screws for that
AWB
04-20-2008 05:22:00
 Re: Idle adjustment screw on Allis G Tractor. in reply to Michael Soldan, 04-19-2008 12:33:15
Michael Soldan: Thanks for the idle adjustment information.
DickL
04-19-2008 12:55:14
It actually does adjust the mixture of fuel to air but just for idle not for run. Miss understood by more than it is understood.
Above idle the air /fuel mixture is controlled by the power jet and the amount of air being pulled into the engine thru the venturi.
You turn the screw in to slow the idle. It is a right hand thread so clock ways is in.
You can not adjust the idle with that screw alone. You have to adjust very small amounts alternating with adjusting the stop screw on the throttle lever on the back of the carb.
AWB
04-20-2008 05:19:42
 Re: Idle adjustment screw on Allis G Tractor. in reply to DickL, 04-19-2008 12:55:14
DickL: Thank you for the information on idle adjustment.
