Tractor Talk Discussion Forum
herbicide help needed...
jose bagge
04-19-2008 07:01:43
Need some advice.
I have an old Civil War era cemetary on the back side of the property right on the edge of the woods. I cleaned it up pretty well, but I have a "sappling" issue- lil' trees and bushes growing up. I can't mow through because of the stones close proximity, and i don't want to kill the ground cover, just the saplings. Ideas?
Jerry/MT
04-19-2008 20:22:39
 Re: herbicide help needed... in reply to jose bagge, 04-19-2008 07:01:43
I"d try Crossbow. It"s used on woody plants. Read the label and see if it"s approved for the use you need.
DiyDave
04-19-2008 16:45:19
If you want to get rid of brush and saplings, cut the tops off to about 8" above groung level with lopers or saw, then paint the stump with roundup herbicide (41% A.I) thinned 1 to 1 with water. This is a legal use of roundup and is in the roundup label. This will kill out most young trees/brush with no damage to anything else. The only thing to watch out for is that some of the big box stores that sell roundup sell some formulations that are really dilute, so don't go by price, compare by A.I. (% active ingredient)
fergienewbee
04-19-2008 10:38:43
There are some good web sites that list most chemicals and their effectiveness and longevity in the soil. Use the least toxic that will do the job.
Larry in Michigan
rednekelmo
04-19-2008 08:14:27
crossbow
Walt davies
04-19-2008 07:22:51
I always use crossbow if they are small saplings, don't get the cheap stuff it won't work as good.
Walt
thurlow
04-19-2008 07:18:36
I'd suggest asking either your extension service or local chemical dealer for what's available/appropiate in your area..... ..Spike, Crossbow, Remedy, Tordon, etc.
treeboy of indiana
04-19-2008 07:17:04
tordon, its 24D same as weedbegone,, get it at a coop or poss. rural king,etc.. put it in an old windex or squit bottle , apply it to the stubs that are freshly cut.. you can always call the count agent 4 advise
Bill in Colo
04-19-2008 13:58:54
 Re: herbicide help needed... in reply to treeboy of indiana, 04-19-2008 07:17:04
Tordon is a restricted use herbicide,sure not 2,4,D weedbegone
John (C-IL)
04-19-2008 18:48:21
 Re: herbicide help needed... in reply to Bill in Colo, 04-19-2008 13:58:54
Tordon RTU is not restricted use and come in a handy applicator bottle.
teddy52food
04-19-2008 07:06:28
Do you know someone that works as a tree trimmer like for a power line? They use a chemical on tree stumps that prevents regrowth.
