Tractor Talk Discussion Forum
Allis model B
kdg
04-16-2008 20:26:28
Hi, I have come across a Allis model B for sale but it has a stuck engine. The plugs and oil are clean and rust/ water free. has anyone had luck freeing up one of these engines enough to run for a short time (obviously I will conduct a rebuild relatively soon) And are these engines fairly easy to rebuild?(I have done many engines before, just not this one)
Thanks!
Jeff-oh
04-17-2008 06:47:35
 Re: Allis model B in reply to kdg, 04-16-2008 20:26:28
FYI if your looking for a good Allis B My father in law is tring to sell his fairly cheep. It runs good and has some implements. He was a motor mechanic in the army during 1960's and has taken good care of it. I know it runs very well.
Send an e-mail if you would like any more info.
Location is in NE Ohio (Youngstown area)
Jeff
old
04-16-2008 21:45:06
#1 drain the oil the dip stick will not show if it has water in the pan but draining it will. #2 fill the cylinders with tranny fluid and let it sit a few day. I have had good/bad luck with the Allis B/C engines and about 50% of the time they pop free
kyleOH
04-16-2008 20:30:39
depends on what kind of stuck it is.. ive had plenty of luck with lightly stuck engines.. i get them running and them hook them to a plow or something to bring em back to life.. now stuck stuck.. thats tricky.
Lanse
04-17-2008 04:16:01
 Re: Allis model B in reply to kyleOH, 04-16-2008 20:30:39
When i got my B from kyleOH, it was stuck. I ended up taking the pistons out through the bottom of the engine. It was a good thing because i found out then that it needed new bearings. I have some pics of it, [email protected] if you want them
kdg
04-16-2008 20:31:59
That is what I am going to try to find out.....
