Tractor Talk Discussion Forum
Need Big Deans Help!!!! Wiring diagram 63' MF 50 Diesel
colin cartmill
04-14-2008 10:26:33
Hey Folks, ive got a 63' MF 50, and she wont turn over, i crossed the solenoid and it starts no problem, i looked underneath and it looks like a Spahgetti explosion of wires. ive got the manuals but they dont say which wires are were, just a crummy picture. HELP!!!!!
Thanks alot
usedtobeiowadave
04-18-2008 12:19:50
 Re: Need Big Deans Help!!!! Wiring diagram 63' MF 50 Diesel in reply to colin cartmill, 04-14-2008 10:26:33
I have had the key switch burn out. Transmission nuetral cut-out switch?
chevdud97
04-14-2008 10:58:09
You should start by checking the fuse. Then check to see if you get voltage to the little wire of the solenoid when you turn the key to start. If the fuse is good and you have voltage to the key switch then the switch is bad. Its a comman problem.
Brown Dirt Cowboy
04-14-2008 10:37:09
Might be easier to find Big Dean over on the Massey page. Could your neutral safety switch be bad? Or maybe the solenoid itself be bad you can jump across a bad solenoid.
colin cartmill
04-14-2008 10:49:18
 Re: Need Big Deans Help!!!! Wiring diagram 63' MF 50 Diesel in reply to Brown Dirt Cowboy, 04-14-2008 10:37:09
I replaced the solenoid. still the same
Brown Dirt Cowboy
04-14-2008 11:01:46
 Re: Need Big Deans Help!!!! Wiring diagram 63' MF 50 Diesel in reply to colin cartmill, 04-14-2008 10:49:18
I would think that the only other part of that starting system would be the starter button switch, could it be bad? I am only going by my 50 gas Massey- Harris. the key switch must be good or you could not start it by jumpimg across the solenoid. When you do find the problem would you please post and let us know? Tom
Colin Cartmill
04-14-2008 11:24:41
 Re: Need Big Deans Help!!!! Wiring diagram 63' MF 50 Diesel in reply to Brown Dirt Cowboy, 04-14-2008 11:01:46
Hello It happens every time, i turn the key and nothing happens, i thought it was the solenoid, so i changed it out, but it did not fix it.
Brown Dirt Cowboy
04-14-2008 11:54:48
 Re: Need Big Deans Help!!!! Wiring diagram 63' MF 50 Diesel in reply to Colin Cartmill, 04-14-2008 11:24:41
Colin I am not familiar with the 50 Diesel, on my gasser the key is on the right side of the dash and there is a starter button on the left side that has to be pushed to start. I had starter button to go bad on a 504 Farmall once so I would think it could happen on a Massey also. Just a thought but do you have the hi-lo shifter in nuetral? Tom
